Ramcharger wont run right #1067860
09/02/11 10:26 PM
09/02/11 10:26 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I have an 88 Ramcharger 4x4... 318 with throttle body. Lately its been having trouble with both starting and running until it is warmed up. When I try to start it, it sometimes takes it a while before it will finally fire off. Then when it does run, it bogs down pretty badly when giving it gas until it warms up. I dont know much about these throttle bodies so any ideas on what could be wrong here?
Re: Ramcharger wont run right [Re: derekeh] #1067861
09/02/11 11:14 PM
09/02/11 11:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
codes???
hall efffect sensor in the dizzy.
I am truckless..
Re: Ramcharger wont run right [Re: 340SHORTY] #1067862
09/03/11 02:47 AM
09/03/11 02:47 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Plugged fuel filter, and/or bad fuel pump in conjunction with possible crud in the throttle body. I would try a filter first, a pump second and then rebuild the throttle body third.
Make sure if you pull the pump, that all the rubber hoses are in good shape. Seen TBI chevys with the hose right after the pump have a split in it so it was always spraying fuel right back into the tank and couldn't build proper fuel pressure. It ran a lot like you're describing. But if you get that far into it, change the pump too. Quite a bit of work to go to, not to change the pump.
Re: Ramcharger wont run right [Re: dodgeboy11] #1067863
09/03/11 09:12 AM
09/03/11 09:12 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Changed the fuel filter and man was it nasty. Im going to see if my local advance has a rebuild kit for the throttle body. Ive never rebuilt one of these but Im thinking their shouldnt be a lot to it?
Re: Ramcharger wont run right [Re: derekeh] #1067864
09/03/11 10:26 AM
09/03/11 10:26 AM
Take a few notes if need b & maybe a pic or 2. Play it by ear
