Which trans pan gasket ? #1067589
09/02/11 05:08 PM
09/02/11 05:08 PM
Sweden
71redcuda Offline OP
Sweden
Does anyone know if the trans pan gasket yearone sells (FD4324) to 727s is the same as the
2464324AC gasket made by nylon over steel in double silicone sealing bead?
www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
thanks,
Nicklas
Re: Which trans pan gasket ? [Re: 71redcuda] #1067590
09/02/11 05:26 PM
09/02/11 05:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any Year One part number that starts with "FD" is a factory direct part, same as you'd find at your dealer.
The factory gasket has a plastic core, not steel.
