318 metal intake gaskets #1067461
09/02/11 02:26 PM
09/02/11 02:26 PM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
Is it okay to use the stock metal intake gaskets with an aluminum manifold? Also, what sealer should be used? I've used the Permatex #2 in the past. Is that still okay?
Thanks,
Ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: 318 metal intake gaskets [Re: kenz] #1067462
09/02/11 03:18 PM
09/02/11 03:18 PM
scratchnfotraction Offline
if both the heads and intake have the small ports,yes
when you use a 360 port size intakes on a small port 318 head,I would not use them,to mutch chance of a mix-match of port size and a leak.
but the mix-match of the 2 size ports is no biggei from a performance stand point,you wont notice it on the street.
I would use a fel-pro 1213 SB intake gasket set,it has the heat cross over block and should help keep the alum intake/carb cool.
I like the mopar ATF/RTV or permatex copper RTV in the 4 corners and a light coat on the cork ends seals
let it cure over night for best results.
Re: 318 metal intake gaskets [Re: scratchnfotraction] #1067463
09/02/11 04:01 PM
09/02/11 04:01 PM
dogdays Offline
dogdays  Offline
I used "The Right Stuff" as my end gaskets. Torqued it down and drove away. It's expensive but it really works. Just don't get it in contact with gasoline.
R.
Re: 318 metal intake gaskets [Re: dogdays] #1067464
09/02/11 04:05 PM
09/02/11 04:05 PM
Gasoline will eat it? yes I hear "the right stuff" is excellent (but pricey) stuff
Re: 318 metal intake gaskets [Re: kenz] #1067465
09/02/11 08:42 PM
09/02/11 08:42 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
I was under the impression that the metal gaskets will "emboss" themselves into the softer aluminum, and composites were recommended.
Re: 318 metal intake gaskets [Re: jerseybud] #1067466
09/04/11 02:53 PM
09/04/11 02:53 PM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
The manifold is a Weiand Stealth and it has the small ports like the heads.
I have some of the "Right Stuff" and planned on using it instead of the end seals. I didn't know what kind of sealer, if any, to use on the side gaskets.
Thanks,
Ken.
www.moparsaz.com
Re: 318 metal intake gaskets [Re: jerseybud] #1067467
09/04/11 05:42 PM
09/04/11 05:42 PM
CA
David Lee Offline
David Lee  Offline
CA
what did mopar use with the 340 six pack setups?
Ah...so many pedestrians, so little time...
