Mopar Spring Perchs... Two different styles???? #1067128
09/01/11 08:05 PM
09/01/11 08:05 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I need to get a set of spring perches.. One set is $13 (.625 hole and 2.500" wide) and the other is $43 (.520 hole and 2.8125" wide)
Why are there two different styles? And which style is for what application? And why the big price difference? I am using SS springs for this application if that helps. I don't have anything to look at right now other wise I would measure it myself for you guys that were wondering
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Mopar Spring Perchs... Two different styles???? [Re: DemonDust] #1067129
09/01/11 08:27 PM
09/01/11 08:27 PM
MI
68shifter Offline
68shifter  Offline
MI
SS springs use the smaller id center pin. I just bought a set of the larger ones from DTS and had them send weld in bushings, all less than $20.
Good luck.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Mopar Spring Perchs... Two different styles???? [Re: DemonDust] #1067130
09/01/11 08:37 PM
09/01/11 08:37 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
You need the ones with the 1/2" hole. I like these the best. There from calvert racing $39 a pair. Rob.
Re: Mopar Spring Perchs... Two different styles???? [Re: DemonDust] #1067131
09/01/11 10:17 PM
09/01/11 10:17 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
there is also a difference in the heights. distance from bottom of the perch to the bottom of the saddle. i think there is a 1/2" difference. that would change ur ride height. stay safe, seeya.
