Nitto NT555R Tires #1066766
09/01/11 08:45 AM
09/01/11 08:45 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Anyone use them?
How fast?
Would you buy them again?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Nitto NT555R Tires [Re: 6bblFLASH] #1066767
09/01/11 02:49 PM
09/01/11 02:49 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I ran them on my 69 Charger for quite a while. Great dual purpose tire that prioritizes street performance over strip.
If you're wanting to go as quick as possible on a drag radial, it's not your best choice. But if you want to run a lot of highway miles, in some respects, it's you're only choice. They have speed (V or Z) and treadwear (100) ratings whereas other drag radials do not.
I drove an entire Hot Rod Power Tour on a set, much of it in the rain, and was very pleased with the performance. Took the car to the strip on several occasions and they hook WAY better than BFG T/As. (T/A's suck in the rain too).
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Nitto NT555R Tires [Re: 471Magnum] #1066768
09/01/11 03:43 PM
09/01/11 03:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I love mine, my BFG T/A's were toast at about 8K, so if these last the same with way better traction I'll be happy, I'm running a 360 with about 400hp and a dynamic 9.5" TC, 4,400rpm flash, Demon ran a 12.22 first and only time out with a 1.66 60' on slicks, haven't run the Nittos at the track but on the street leaning on the converter i get very minimal spin maybe 2 or 3 revolutions.
Re: Nitto NT555R Tires [Re: ademon] #1066769
09/01/11 03:45 PM
09/01/11 03:45 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
2nd
Re: Nitto NT555R Tires [Re: 6bblFLASH] #1066770
09/01/11 05:52 PM
09/01/11 05:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Excellent street manners with incredible street traction. No track time on them yet.
Re: Nitto NT555R Tires [Re: 471Magnum] #1066771
09/03/11 02:32 PM
09/03/11 02:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would have to go the opposite way on this. I ran some 555rs on my mustang while they worked great on the street they were scary in the rain. I went to a BFG Radial TA in the same size(275/50/15) and they worked much better on the track and had good wet weather perofmance and I needed that because it was my DD. They didn't hook near as good as the nittos on the street though. And I loved the look of the 555rs smooth sidewall when it was shined up.
I ended up with a 1.85 60ft on the radial TAs with a 5-speed mustang, about a tenth better than I could do with the 555rs and only a 10th slower than slicks. The little 306 bogged pretty bad on the slicks though so its not a real good comparison.
68 Barracuda Formula S 340
Re: Nitto NT555R Tires [Re: Bad340fish] #1066772
09/03/11 03:35 PM
09/03/11 03:35 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I could see a stick car potentially doing better with the T/As. A little tire spin is better than slipping the clutch or a bog.
For grip though, Nittos were WAY better on my Charger with the auto. No 60 ft times to compare, but I always had to walk it out of the hole with the T/As. Full throttle just resulted in blowing the tires off. Nittos could handle full throttle with minimal spin.
Once I converted the car to a stick, I never really did get it to launch well. With the Nittos, I had more traction than clutch. Installed a Slide-A-Link to control the wheel hop, and then I started having clutch problems. Sold the car before I got sorted out completely.
Mustangs are pretty scary in the rain no matter what tire you've got on them. I've owned a couple.
-Jim
Re: Nitto NT555R Tires [Re: 471Magnum] #1066773
09/03/11 09:35 PM
09/03/11 09:35 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
look into a General G-Max AS, not for sure what you want them for, but my customers have been very happy with them
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
