Tire pressure at the track
#1066725
09/01/11 02:44 AM
09/01/11 02:44 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Hey Fellas, I understand everyone's car is different and you have to see what each car needs. With that said, when are you checking and adjusting your tire pressures. I check them cold before the run and then after. I had them adjusted at 12.5 cold, and my buddies at the track kept nagging me to lower them to about 10 when they were hot. I know that is a big drop (cold to hot). I gradually lowered them each run finally to 10. My 60 ft. did get slightly faster (1.65 to 1.56), but when I got home and watched the videos, It looks like the sidwall is distorting too much at 10 psi. My car is a street car and weighs 4000 with me. What do you think looking at the pics. (These photos are in reverse order) Thanks for any input.
Re: Tire pressure at the track
[Re: Mr.Yuck]
#1066727
09/01/11 08:57 AM
09/01/11 08:57 AM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
Does the car bounce at all on leaving the line? looks like you are getting a bit of a ball in front of the tire which could cause that. It also at the same time looks like the rear is hitting real good. I,ve always been told to run as much air as you can get away with. Ie. bouncing off the line or hard to steer at top end with to low of pressure.
67 cuda new best 1.395 60 10.240 at 128.58mph
[Re: Chargerfan68]
#1066729
09/01/11 12:00 PM
09/01/11 12:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your KILLING your side walls... up the pressure and if need be start adjusting the suspension to correct for it(preload on the caltracks and shock settings) set the front end loose
[Re: MR_P_BODY]
#1066730
09/01/11 09:13 PM
09/01/11 09:13 PM
Posts: 16,928 NC
440Jim
NC
That is killing the tire. If you need to run like that to prevent spin, you need to work on the chassis. Can you give us more info on what was happening when you dropped the air pressure and improved sixty foot time? i.e. spin, hook then spin, turn the tire then hoook, etc. Just the number doesn't tell enough of the story.
[Re: MR_P_BODY]
#1066732
09/02/11 12:34 AM
09/02/11 12:34 AM
Chargerfan68
New York, USA
Thanks...The front end is very loose, and I have just about 5 1/2 inch of travel. I notice on the vids, when I dump the clutch, the rear just drops violently. I have my shocks on 21 out of 24 stiff. needs more stiffness I guess. I believe the track was not as good as previous times. This was a track rental, and I was just about the only car there running. There was no fresh rubber down. So instead of adjusting my preload and shocks, I started chasing with air. My mistake.
[Re: 440Jim]
#1066733
09/02/11 12:44 AM
09/02/11 12:44 AM
Chargerfan68
New York, USA
My friends at the track said the tire was spinning and I should lower air. After slowly lowering air, my 60s got slightly better, but I think that was the track getting a little better with some fresh rubber.
After looking at the vids of the first few runs, the tire just spun 1-2 times then hooked. That's the ideal situation that should result in better 60s.
I didn't touch the bars all day since the car was launching straight ...just barely touching on Drivers side, 3/4 turn preload on pass. Shocks set on 21 rebound/16 compression. Tires run 1 set to 12.5 lbs, and adjusted 4 times down to 10 hot for the 10th and 11th run.
My fasted 60 foot was 1.49 at different track , but it was 6 degr. cooler that day and an event day.
Any other info needed?
Thanks.
[Re: Chargerfan68]
#1066735
09/02/11 07:41 AM
09/02/11 07:41 AM
MR_P_BODY
On a good biting track you can have your shock tight but on a bad or not so good of biting track you want to loosen the shocks up... what hole so you have your caltracks in... you will need them in the lower hole and then start on the shock adjustment EDIT Are you foot braking or trans brake... if I launch at lower rpms I need more air pressure than if I launch at higher rpms
[Re: MR_P_BODY]
#1066737
09/02/11 10:46 AM
09/02/11 10:46 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
He says he's dumping the clutch & from his pic looks like the bars are in the lower hole.
I would start out with 11 psi "cold" & play with shock settings, Like MrP said, at a better hooking track you can have a tighter shock setting, you just need to balance out the 2, shocks/tire pressure, all your really after is the best hook/60ft without slamming the suspention, alittle bit trickier on a stick car.
I notice too the front end isn't coming up much, your right, it is good to have a little bit of tire spin for best 60fts on a stick car, gets you past any boggs.
[Re: 383man]
#1066738
09/02/11 10:49 AM
09/02/11 10:49 AM
joedust451
super gas
super gas
Branson, Mo.
I run theses 30 x 9 Hoosier radial slicks and I run at least 15 or more as on good tracks they will hook with almost 20 in them. And I have been driving on the street with them for almost 2 years. I see your best 60 is 1.49 and thats a great 60 for a low 11 car. Guess them Cal Tracs really work. I would definetly try as everyone says and raise the psi so they dont wad up. How old are the tires ? Ron
Ron, i think those are ET streets Bias ply.
[Re: joedust451]
#1066739
09/02/11 11:35 AM
09/02/11 11:35 AM
MR_P_BODY
Yeah I forgot about it being a stick car.... but all of the same aspects still apply
[Re: 383man]
#1066741
09/02/11 02:17 PM
09/02/11 02:17 PM
joedust451
super gas
super gas
Branson, Mo.
No believe me they are the radial slicks. The same kind many of the NHRA stockers run. No tread on them. Ron
Oh OK, well then he's running way to low pressure.
