Does the car bounce at all on leaving the line? looks like you are getting a bit of a ball in front of the tire which could cause that. It also at the same time looks like the rear is hitting real good. I,ve always been told to run as much air as you can get away with. Ie. bouncing off the line or hard to steer at top end with to low of pressure.
67 cuda new best 1.395 60 10.240 at 128.58mph
