Alky users what oil viscosity?????????//
#1066690
08/31/11 11:06 PM
08/31/11 11:06 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Just curious guy's, what oil viscosity are you running with your alky engines, I am planning to do a litle testing with the stuff, and it's time for an oil change, so I thought I would kill two birds with one stone, and change the oil before I ran the alky, I have always used valvoline 10w30, but I am going to use a straight 30wt to do some testing with, so I thought I would see what everyone runs in their alky engines.
Thanks Dave
Re: Alky users what oil viscosity?????????//
[Re: 65racer]
#1066691
08/31/11 11:52 PM
08/31/11 11:52 PM
Posts: 2,524 PA
moparacer
PA
Depends on how quick you trash it with water contamination.
I run mine on alky at 170-180 degrees and it stays cleaner then it did on gas.
20/50 Brad Penn or 20/50 VR1 is what I run.
The 25/50 Pennzoil is excellent alky oil too.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 65racer]
#1066695
09/01/11 10:16 AM
09/01/11 10:16 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The only change in oil type would be related to not keeping the oil alky/water free. Like these guys say, keep it WARM, don't let it idle rich for extended periods and don't shut it off without getting the temp up to 190 or so. You will need some form of lean out system. Either a ball valve plumbed to the intake for carbs, or a shutoff valve for an injecter. Try and get idle exhaust temp up over 800 degrees, not above 1,000.
[Re: gregsdart]
#1066696
09/01/11 10:33 AM
09/01/11 10:33 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
20/50 Brad Penn here
[Re: Diablo]
#1066698
09/01/11 02:00 PM
09/01/11 02:00 PM
Posts: 901 oh
julian2007
oh
Brad Penn 30 wt We use a AED 1050 and I have a lean out valve but don't need it, my carb uses a little under a gal a lap,Oil is always clean.To be honest I sent my 1050 to aed for the alky conversion and I don't act any different than it did on gas it starts the same,warms up the same,uses about the same amount of fuel and is just as clean as gas was.The differences were about a tenth quicker and it hits a brick wall 190 degrees of temp.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
