Re: Diesel lift pump (long)
[Re: poison_ivy]
#1066320
09/01/11 02:36 AM
09/01/11 02:36 AM
Posts: 75,085 A Banana Republic near you.
JohnRR
Spoke with a mechanic at a different dealer today that said they have NEVER had a retro fit pump come back with a failure. I'm just not sure if I'm just worrying too much. This truck runs fine and is all I need. Total combined weight when I'm towing to the track is 14,720. I'm told that's not bad for a diesel. I've gone back and forth with this for a couple of weeks. I know most guys want more hp and torque, but for the most part I'm satisfied with what I have. This is my first diesel, and everyone I talk to says you need to do this and do that. I don't need a monster truck. I just want something reliable and dependable. With that said, am I making too much about this?
No , that fuel pressure is TOO LOW , do you want to have to replace the injector pump $$$ ??? , then leave it as is ...
[Re: JohnRR]
#1066321
09/01/11 02:43 PM
09/01/11 02:43 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Don't believe the dealer; if I had a penny for every time I've heard the "we've never encountered that" story, I'd be a rich man. Funny thing is that often the issue (like this one) is well known to be VERY common.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1066322
09/01/11 03:09 PM
09/01/11 03:09 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I can tell you this since I worked for a Dodge dealer for 23 years. Every time I saw a tech replace a low pressure lift pump mech or electric if they did not replace the inj pump it would be towed back in a few days to get the inj pump replaced. The fuel has a return line at the injector pump and the extra fuel would go thru that line along the side of the inj pump back to the tank and that fuel would help cool the inj pump. And every time the lift pump went bad they ended up needed the inj pump either right then or within a week or so. Now after we started putting the low pressure pump in the tank as long as the inj pump was also replaced I did not see them come back. So it definetly helped and worked better with the in tank pump but it is not as good as most after market kits. Ron
[Re: DPelletier]
#1066324
09/01/11 04:53 PM
09/01/11 04:53 PM
JohnRR
The VP44 is VERY succeptible to damage from low lift pump pressure. ...
HOGWASH ....
I ran my truck out of fuel more times than I care to admit , I did it so many times I figure out how to prime it without having to crack lines, went thru 3 lift pumps, one died completely and I drove the truck for 3 months with the VP pulling fuel thru a dead lift pump, I lost the voltage signal from the ECM. The original VP died at about 220k miles and that was in my opinion because of the low sulfur fuel ... coupled with the 3rd 14psi pump only pushing 5psi...
[Re: JohnRR]
#1066325
09/01/11 06:15 PM
09/01/11 06:15 PM
DPelletier
HOGWASH ....
Yeah, but you're special! Many of us weren't so lucky. I was soooo happy the day my '01 was traded for a new common rail truck! (in hindsight, the '01 was a great truck too)
1974 'Cuda
[Re: fox]
#1066329
09/06/11 12:53 AM
09/06/11 12:53 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Dodge knows that an engines fuel requirements are "volume" related and pressure is only a tool to get that volume. An engines fuel requirement is measured in B.S.F.C., or Brake Specific Fuel Consumption, which ballpark is about .5lbs of fuel per HP per hour. The engine could care less if the fuel is delivered at 10 or 10,000PSI; it wants 200LBS of fuel (about 30 gallons) to make 400HP per hour. Asking for a certain volume takes all the guesswork out of the equasion. If the line supplying the injector pump can fill a gallon container in a minute, you have enough fuel to make roughly 780HP, or about 620HP running at the 80% duty factor a lot of fuel systems are set up at. By Dodge asking for a certain volume it takes all the custom or modified fuel system arguements out of the equasion. If a stock and unmodified fuel system doesn't meet that volume spec - that is a Dodge issue. If the retrofit Widget Industries lift pump plumbed in with Home Depot fittings only flows a pint of fuel a minute @ 15PSI - not Dodges problem. Again my point - Pressure is a tool to obtain volume; not an accurate indicator of OBTAINED VOLUME.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: fox]
#1066331
09/06/11 01:46 AM
09/06/11 01:46 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
My point really was that Dodge got tired of people finding low pressure at the injection pump, so they thru a curve to avoid replacing so many cheap pumps. (cheap by design)
....actually Chrysler bought the package from Cummins, and it was Chysler that absorbed the expense of replacing all those VP's and lift pumps. It was also on the common rail trucks (03-04) that the "supplied" lift pump was also a failure prone piece. It was chrysler that came up with the in-tank pump that appeared stock in 05, but retrofit kits went all the way back to the 98.5 VP equipped trucks. I do remember hearing the the warranty cost was such that during the Diamler era they were looking hard at replacing the Cummins with a Mercedes based package. That would have most likely been the death of Dodge trucks, but it would have kept costs "in house" too.
