Diesel lift pump (long) #1066312
08/31/11 12:58 AM
08/31/11 12:58 AM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
Just bought my first diesel. Found a great deal on an '02 with 41,000 miles. Runs great and looks like new. A friend checked and found out I have low fuel pressure,(6-7). I bought a FASS DDRP to replace the lift pump. Discovered the truck has a retro-fit in tank pump. Can this be removed and the FASS be mounted on the rail? Service rep at the Dodge dealer says the in tank setup can't be removed because it's now tied into the PCM. I located an original fuel level sending unit module to to put back in, in place of the in tank unit. What headaches am I going to encounter in this swap?
Re: Diesel lift pump (long) [Re: poison_ivy] #1066313
08/31/11 03:02 AM
08/31/11 03:02 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
use the new pump , trash the one in tank , buy more mopar parts with money you save from not needing a new injection pump !
Re: Diesel lift pump (long) [Re: calrobb2000] #1066314
08/31/11 09:06 AM
08/31/11 09:06 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Yes, get rid of the sad in-tank pump. It won't work together.
I have an 02 also. It has amused me for 10 years now to watch dodge spend $1,000 to almost fix something when all they had to do was buy it aftermarket!!! And, for $500.
Re: Diesel lift pump (long) [Re: poison_ivy] #1066315
08/31/11 09:19 AM
08/31/11 09:19 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Where did you measure that 6-7 psi pre filter or post, not that it matters much because that is still too low even with a clogged filter.
Change it out and don't look back.
Re: Diesel lift pump (long) [Re: poison_ivy] #1066316
08/31/11 01:07 PM
08/31/11 01:07 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Cummins is more interested in fuel FLOW than fuel pressure. Pump output is measured in mL for a 20 second period.
Re: Diesel lift pump (long) [Re: teflon] #1066317
08/31/11 05:37 PM
08/31/11 05:37 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have an '02, 6spd, 2wd truck with 55k miles on it now . . . did the lift pump earlier this year (about 5k miles ago) . . . have pressure gauge on before I changed the lift pump. It was factory original Carter electric on left rear of engine . . . your in tank lift pump must have been changed out at some point, pretty sure they had the Carter Electric mounted on the block.
I went with the FASS stock replacement pump . . . however, I just replaced the injection pump after getting the dreaded dead pedal syndrom and the 0216 code (injection pump timing error) . . . truck is running fine again . . . nothing that $2.5k couldn't fix ! Ha ha ha . . . that was me doing the lift pump myself, and then having a shop do the injection pump.
The shop recommends a fuel additive to counteract the ultra low sulphor fuel out there now !!! . . . fyi !
Cheers
Mark
Re: Diesel lift pump (long) [Re: teflon] #1066318
08/31/11 06:26 PM
08/31/11 06:26 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I know that. But if you understand flow, the pressure drops then volume does too!
They are directly proportional.
Re: Diesel lift pump (long) [Re: fox] #1066319
08/31/11 10:27 PM
08/31/11 10:27 PM
Visalia, CA.
P
P
Visalia, CA.
Spoke with a mechanic at a different dealer today that said they have NEVER had a retro fit pump come back with a failure. I'm just not sure if I'm just worrying too much. This truck runs fine and is all I need. Total combined weight when I'm towing to the track is 14,720. I'm told that's not bad for a diesel. I've gone back and forth with this for a couple of weeks. I know most guys want more hp and torque, but for the most part I'm satisfied with what I have. This is my first diesel, and everyone I talk to says you need to do this and do that. I don't need a monster truck. I just want something reliable and dependable. With that said, am I making too much about this?
Re: Diesel lift pump (long) [Re: poison_ivy] #1066320
09/01/11 02:36 AM
09/01/11 02:36 AM
JohnRR Offline
JohnRR  Offline
No , that fuel pressure is TOO LOW , do you want to have to replace the injector pump $$$ ??? , then leave it as is ...
Re: Diesel lift pump (long) [Re: JohnRR] #1066321
09/01/11 02:43 PM
09/01/11 02:43 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Don't believe the dealer; if I had a penny for every time I've heard the "we've never encountered that" story, I'd be a rich man. Funny thing is that often the issue (like this one) is well known to be VERY common.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Diesel lift pump (long) [Re: DPelletier] #1066322
09/01/11 03:09 PM
09/01/11 03:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you this since I worked for a Dodge dealer for 23 years. Every time I saw a tech replace a low pressure lift pump mech or electric if they did not replace the inj pump it would be towed back in a few days to get the inj pump replaced. The fuel has a return line at the injector pump and the extra fuel would go thru that line along the side of the inj pump back to the tank and that fuel would help cool the inj pump. And every time the lift pump went bad they ended up needed the inj pump either right then or within a week or so. Now after we started putting the low pressure pump in the tank as long as the inj pump was also replaced I did not see them come back. So it definetly helped and worked better with the in tank pump but it is not as good as most after market kits. Ron
Re: Diesel lift pump (long) [Re: 383man] #1066323
09/01/11 04:21 PM
09/01/11 04:21 PM
DPelletier Offline
DPelletier  Offline
Ron,
Yep; I can buy into all of that. My comment was on the generic "we've never seen that before" spew when the parts are on national back order because it happens so often! Think, 2nd gen clockspring or AC blender doors!
The VP44 is VERY succeptible to damage from low lift pump pressure. In the case of the OP, the pressures he's seeing are still too low and I'd rely on the pressure gauge over the "the updated pump is never a problem" sentiments. It simply is NOT worth the risk.
Re: Diesel lift pump (long) [Re: DPelletier] #1066324
09/01/11 04:53 PM
09/01/11 04:53 PM
JohnRR Offline
JohnRR  Offline
The VP44 is VERY succeptible to damage from low lift pump pressure. ...
HOGWASH ....
I ran my truck out of fuel more times than I care to admit , I did it so many times I figure out how to prime it without having to crack lines, went thru 3 lift pumps, one died completely and I drove the truck for 3 months with the VP pulling fuel thru a dead lift pump, I lost the voltage signal from the ECM. The original VP died at about 220k miles and that was in my opinion because of the low sulfur fuel ... coupled with the 3rd 14psi pump only pushing 5psi...
Re: Diesel lift pump (long) [Re: JohnRR] #1066325
09/01/11 06:15 PM
09/01/11 06:15 PM
DPelletier Offline
DPelletier  Offline
HOGWASH ....
Yeah, but you're special! Many of us weren't so lucky. I was soooo happy the day my '01 was traded for a new common rail truck! (in hindsight, the '01 was a great truck too)
Re: Diesel lift pump (long) [Re: DPelletier] #1066326
09/02/11 06:44 PM
09/02/11 06:44 PM
South Coast of Oregon
dweller Offline
dweller  Offline
The in tank pump on my '02 HO has been working fine for the past 60K miles. Lift pump on the block is stock for these trucks. Mine was replaced on warranty at 90K along with a new IP. I try to keep my tank at least 1/4 full so the pump is partially submerged.
IP failures have to do with heat cycles, not so much keeping the board cool.
Re: Diesel lift pump (long) [Re: fox] #1066327
09/04/11 02:17 AM
09/04/11 02:17 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
If you really understand flow you understand that pressure is a measurement of restriction. Thats why pumps are rated X volume @ X pressure, as in 140 gallons @ 7 P.S.I.. Thats the reason Dodge wants to see a certain volume in a certain amount of time. A restriction between the lift pump and the injector pump can show good pressure (at the pump) but still have low volume.
I've seen cobbled together fuel systems that showed good pressure, but the small hoses and fittings wouldn't flow any real volume. If the point of the most restriction is between the carb (or injector pump) and where you are reading the pressure, you won't get an accurate read on the amount of fuel avalible, as in good pressure - low volume.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Diesel lift pump (long) [Re: Evil Spirit] #1066328
09/05/11 03:55 AM
09/05/11 03:55 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Of course I understand flow.
My point really was that Dodge got tired of people finding low pressure at the injection pump, so they thru a curve to avoid replacing so many cheap pumps. (cheap by design)
If you have a hydraulic system and change nothing, if the pressure drops so does the voluume.
Ddoge simply twisted the talk to the customer that had low pressure and said the pressure wasn't important, it was the flow they were concerned about!
But, Bosch states 'pressure to the pump at a certain spec range. They do NOT specify the voluume. either would be acceptable. My poit is dodge tried to sell customers that if the pressure was low or zero, they still only were concerned of flow. Of course we know id pressure is a true zero there will be no flow.
Re: Diesel lift pump (long) [Re: fox] #1066329
09/06/11 12:53 AM
09/06/11 12:53 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Dodge knows that an engines fuel requirements are "volume" related and pressure is only a tool to get that volume. An engines fuel requirement is measured in B.S.F.C., or Brake Specific Fuel Consumption, which ballpark is about .5lbs of fuel per HP per hour. The engine could care less if the fuel is delivered at 10 or 10,000PSI; it wants 200LBS of fuel (about 30 gallons) to make 400HP per hour.
Asking for a certain volume takes all the guesswork out of the equasion. If the line supplying the injector pump can fill a gallon container in a minute, you have enough fuel to make roughly 780HP, or about 620HP running at the 80% duty factor a lot of fuel systems are set up at. By Dodge asking for a certain volume it takes all the custom or modified fuel system arguements out of the equasion. If a stock and unmodified fuel system doesn't meet that volume spec - that is a Dodge issue. If the retrofit Widget Industries lift pump plumbed in with Home Depot fittings only flows a pint of fuel a minute @ 15PSI - not Dodges problem.
Again my point - Pressure is a tool to obtain volume; not an accurate indicator of OBTAINED VOLUME.
Re: Diesel lift pump (long) [Re: Evil Spirit] #1066330
09/06/11 01:30 AM
09/06/11 01:30 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Run the intank pump, it will do just fine.
Re: Diesel lift pump (long) [Re: fox] #1066331
09/06/11 01:46 AM
09/06/11 01:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....actually Chrysler bought the package from Cummins, and it was Chysler that absorbed the expense of replacing all those VP's and lift pumps. It was also on the common rail trucks (03-04) that the "supplied" lift pump was also a failure prone piece. It was chrysler that came up with the in-tank pump that appeared stock in 05, but retrofit kits went all the way back to the 98.5 VP equipped trucks. I do remember hearing the the warranty cost was such that during the Diamler era they were looking hard at replacing the Cummins with a Mercedes based package. That would have most likely been the death of Dodge trucks, but it would have kept costs "in house" too.
