Re: Painting wheels
[Re: JoesMopar]
#1066235
08/30/11 11:28 PM
08/30/11 11:28 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
some will tell you that you need to take them off, and will suggest expensive powder coating. others will tell you to spray bomb it. and then some will say "you get what you pay for" your call! but, as an FYI, I painted my wheels about 4 years ago now, with rustoleum spray bombs from Wal-mart. I used flat black. sanded the wheels with 400 grit paper inside and out, cleaned them up, wiped them down, I took probably 45 minutes per wheel, sanding it, cleaning it, washing it, looking for spots in the factory powdecoat finish that were still shiney, and sanding them some more. once I was happy, I put masking tape around the edge, and sprayed them. here's how they look today. and with the rims in direct sunlight: [image]oops...that was bigger than I thought...see attachment instead, different, smaller pic![/image] no chips, no flakes, nice even color, I'm happy with it for the $12 I spent in paint. if they ever do start to flake/chip on me...when it gets bad enough, I'll spend another $12 and spray bomb them again. ...and I did all this with the tires on the rims.
**Photobucket sucks**
Re: Painting wheels
[Re: JoesMopar]
#1066236
08/30/11 11:29 PM
08/30/11 11:29 PM
Posts: 564 Round Rock,Tx
Nirvana
Round Rock,Tx
Remove wheel from car,mark wheel weight location with chalk on tire,remove wheel weight(s),cover tire with news paper,scuff wheel,prime,then paint. Stick them out in the sun till they dry,remove news paper,reinstall wheel weights and remount on the car.
