Painting wheels #1066232
08/30/11 11:11 PM
08/30/11 11:11 PM
USA
JoesMopar Offline OP
USA
Is there a trick to painting wheels while they're on the car or is it preferred to dismount the tire from them?
I have a Diplomat ex cop car that is white with the police slotted wheels and dog dishes. The wheels are black and I would like to repaint them white but don't really want to go through the hassle of pulling the tires off, taking them somewhere to dismount etc etc.
Is it ok to use just a regular spray paint like Krylon or something similar with a clear coat or is that going too far?
Thanks for any info.
Re: Painting wheels [Re: JoesMopar] #1066233
08/30/11 11:27 PM
08/30/11 11:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I have painted plenty of wheels without taking off the tires. Lot's of masking tape works just fine. I wouldn't mess with clear...just something to flake off, use single stage.
Re: Painting wheels [Re: JoesMopar] #1066234
08/30/11 11:27 PM
08/30/11 11:27 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
To do it correctly, dismount the tires...then you can properly clean, prep, and paint them completely.
Re: Painting wheels [Re: JoesMopar] #1066235
08/30/11 11:28 PM
08/30/11 11:28 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
some will tell you that you need to take them off, and will suggest expensive powder coating.
others will tell you to spray bomb it.
and then some will say "you get what you pay for"
your call!
but, as an FYI, I painted my wheels about 4 years ago now, with rustoleum spray bombs from Wal-mart. I used flat black. sanded the wheels with 400 grit paper inside and out, cleaned them up, wiped them down, I took probably 45 minutes per wheel, sanding it, cleaning it, washing it, looking for spots in the factory powdecoat finish that were still shiney, and sanding them some more.
once I was happy, I put masking tape around the edge, and sprayed them.
here's how they look today.
and with the rims in direct sunlight:
[image]oops...that was bigger than I thought...see attachment instead, different, smaller pic![/image]
no chips, no flakes, nice even color, I'm happy with it for the $12 I spent in paint.
if they ever do start to flake/chip on me...when it gets bad enough, I'll spend another $12 and spray bomb them again. ...and I did all this with the tires on the rims.
**Photobucket sucks**
Re: Painting wheels [Re: JoesMopar] #1066236
08/30/11 11:29 PM
08/30/11 11:29 PM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Remove wheel from car,mark wheel weight location with chalk on tire,remove wheel weight(s),cover tire with news paper,scuff wheel,prime,then paint. Stick them out in the sun till they dry,remove news paper,reinstall wheel weights and remount on the car.
Re: Painting wheels [Re: 70Cuda383] #1066237
08/30/11 11:31 PM
08/30/11 11:31 PM
USA
USA
Thanks for all the info guys, this thing is just a beater anyway but it's growing on me...
Re: Painting wheels [Re: JoesMopar] #1066238
08/30/11 11:44 PM
08/30/11 11:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't use masking tape, it takes too much and is a nuisance and rarely wants to stick to the tire. Instead I brush paint the tires with straight dishwash detergent - its thick enough not to puddle at the rim and doesn't matter if it dries. I paint the rims then wash the detergent off when I'm satisfied the paint has dried long enough. If there is any minor seepage of paint through the soap it will come off easily with lacquer thinner. Oh, I do this with the wheels OFF the car and laying flat!
Re: Painting wheels [Re: JoesMopar] #1066239
08/30/11 11:46 PM
08/30/11 11:46 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Remove them from the car.... no oversray on lugnuts etc. For driver beater wheels I've degreased, and sanded them, then used trash bags and carefully razored out the rim circumference, then masked/taped, then painted
Re: Painting wheels [Re: UCUDANT] #1066240
08/31/11 12:04 AM
08/31/11 12:04 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
If you decide to paint them with the tires mounted, I have found that masking the perimeter is easy using decks of cards. You just shove cards in between the tire and wheel all the way around slightly overlapping into the next, then do what ya gotta do. Works great and isnt a PITA like masking tape.
Re: Painting wheels [Re: POS Dakota] #1066241
08/31/11 12:13 AM
08/31/11 12:13 AM
is easy using decks of cards. Works great and isnt a PITA like masking tape.
& I need 2 paint a set also EDIT have a cheap HF sandblaster that looks like a spray gun w an open funnel on top & they had sand media on sale for $3 a box. I'll find out soon how it goes
Re: Painting wheels [Re: RapidRobert] #1066242
08/31/11 01:34 AM
08/31/11 01:34 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
For a beater, or daily driver that isn't a $50000 car, its pretty easy to look good. Pulling the wheels off the car is a given... if only to get consistent color on the rims and take some hassle out ov the job. Pulling tires off the rim is the BEST way, as even the best masking job wont look quite as good. I've never bothered to blast or prep the rims though... just get 'em free ov tires, clean and bomb 'em. Looks damn good, unless your wheels are beat or have 5 different paint jobs on them already, in which case it really will be better to blast 'em first.
This cost $5. Goes nice with the $60 paint job.
Re: Painting wheels [Re: Pale_Roader] #1066243
08/31/11 07:32 AM
08/31/11 07:32 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Leave the tires mounted. Don't use masking tape. Go to the dollar store and but a pack of playing cards. Lay the cards on the wheels and spray paint your wheels.
Re: Painting wheels [Re: MadMax58] #1066244
08/31/11 03:16 PM
08/31/11 03:16 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
I've also heard someone mentioning to let some air out of the tires so you have a gap to put say playing cards or cardboard in there.
Re: Painting wheels [Re: CDN72SE] #1066245
08/31/11 03:27 PM
08/31/11 03:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
Some great ideas here, thanks for posting them.
