906 heads question #1066203
08/30/11 10:12 PM
08/30/11 10:12 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
On the #8 cylinder header bolt (last one in the back)
Does the header stud go into a water jacket?
Re: 906 heads question [Re: wldgtx] #1066204
08/30/11 10:31 PM
08/30/11 10:31 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
Okay I think I figured it out.
The last header stud on #8 cylinder (back towards fierwall) must go into a water jacket.
I need to get some thread sealer...
Re: 906 heads question [Re: wldgtx] #1066205
08/30/11 10:33 PM
08/30/11 10:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
all the exhaust header/manifold bolt holes are wet. i use studs with arp thread sealer whether i use manifolds or headers.
Re: 906 heads question [Re: lewtot184] #1066206
08/30/11 10:34 PM
08/30/11 10:34 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
You are correct sir!
Thank you, I will do just that!
Re: 906 heads question [Re: wldgtx] #1066207
08/31/11 11:13 AM
08/31/11 11:13 AM
The OE type studs w the unthreaded shoulder in the middle seal the best (w sealer as mentioned) & you mentioned headers & you can trim the outer fine thread portion so there's only enough threads left 4 a thin high grade nut 2 fit flush which greatly helps fitment
