904 stuck in low... #1065993
08/30/11 05:51 PM
08/30/11 05:51 PM
PA
maxwedge1 Offline OP
PA
car been sitting for many years...owner said he flushed it and changed fluid and had to fab up some of the missing kickdown linkage.
car wont shift out of low gear.
any quick way to determine if the kickdown linkage is not adjusted properly or the problem is internal?
Re: 904 stuck in low... [Re: maxwedge1] #1065994
08/31/11 05:17 PM
08/31/11 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Disconnect the linkage at the transmission lever, if it will upshift the problem is in the linkage.
Re: 904 stuck in low... [Re: maxwedge1] #1065995
08/31/11 05:50 PM
08/31/11 05:50 PM
Florida STAYcation
dOOc Online penguin-006
The village idiot's idiot
dOOc  Online Penguin-006
Florida STAYcation
The linkage is probably JAMMED ... all the way back.
Re: 904 stuck in low... [Re: dOOc] #1065996
09/01/11 12:01 AM
09/01/11 12:01 AM
PA
PA
thanks...so with kickdown disconnected it should up shift if problem isnt internal or shift linkage.
Re: 904 stuck in low... [Re: maxwedge1] #1065997
09/01/11 01:33 AM
09/01/11 01:33 AM
Florida STAYcation
Florida STAYcation
JUST CHECK ...if the KD lever moves freely with the throttle action.
Re: 904 stuck in low... [Re: dOOc] #1065998
09/01/11 09:43 AM
09/01/11 09:43 AM
If the KD is good then plan on pulling the pan unless you are advised to check the 2 band adjustments 1st. Not sure what 2 check next (I'll defer to Kunkel) but inside you'll immed c if the struts are in place & may need 2 pull the VB & do air checks in the case ports w your rubber tipped shop air nozzle
Re: 904 stuck in low... [Re: maxwedge1] #1065999
09/01/11 10:28 AM
09/01/11 10:28 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If the governor's weights are sticking, it will not shift either. If you take the tail housing off, the weights should move freely when you rotate the output shaft. If they are stuck, there is no signal to the valve body to shift the transmission. Been there, done that, have the T shirt.
Craig
Re: 904 stuck in low... [Re: denfireguy] #1066000
09/01/11 01:00 PM
09/01/11 01:00 PM
What Craig said & I think you can check the governor psi at the port back there & not have to open it up (unless it is stuck)
Re: 904 stuck in low... [Re: RapidRobert] #1066001
09/01/11 01:03 PM
09/01/11 01:03 PM
Florida STAYcation
Florida STAYcation
A stuck gov ? ... that is a rare bird ..... uNless you have some severely toasted ATF in there.
Re: 904 stuck in low... [Re: dOOc] #1066002
09/01/11 03:57 PM
09/01/11 03:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've seen lots of cobbled-together linkages that hold the lever back over half way at idle.
Re: 904 stuck in low... [Re: John_Kunkel] #1066003
09/01/11 05:46 PM
09/01/11 05:46 PM
Florida STAYcation
Florida STAYcation
x 2 ....plus some are missing the return spring
Re: 904 stuck in low... [Re: dOOc] #1066004
09/01/11 07:02 PM
09/01/11 07:02 PM
and then there's the occasional linkage foul up that wont let the throttle open all the way.
