Re: 904 stuck in low...
[Re: maxwedge1]
#1065994
08/31/11 05:17 PM
08/31/11 05:17 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disconnect the linkage at the transmission lever, if it will upshift the problem is in the linkage.
[Re: BeEtLeJuIcE !]
#1065998
09/01/11 09:43 AM
09/01/11 09:43 AM
RapidRobert
If the KD is good then plan on pulling the pan unless you are advised to check the 2 band adjustments 1st. Not sure what 2 check next (I'll defer to Kunkel) but inside you'll immed c if the struts are in place & may need 2 pull the VB & do air checks in the case ports w your rubber tipped shop air nozzle
[Re: maxwedge1]
#1065999
09/01/11 10:28 AM
09/01/11 10:28 AM
Posts: 1,822 Colorado
denfireguy
Colorado
If the governor's weights are sticking, it will not shift either. If you take the tail housing off, the weights should move freely when you rotate the output shaft. If they are stuck, there is no signal to the valve body to shift the transmission. Been there, done that, have the T shirt. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1066000
09/01/11 01:00 PM
09/01/11 01:00 PM
RapidRobert
What Craig said & I think you can check the governor psi at the port back there & not have to open it up (unless it is stuck)
[Re: BeEtLeJuIcE !]
#1066002
09/01/11 03:57 PM
09/01/11 03:57 PM
John_Kunkel
Rio Linda, CA
I've seen lots of cobbled-together linkages that hold the lever back over half way at idle.
[Re: BeEtLeJuIcE !]
#1066004
09/01/11 07:02 PM
09/01/11 07:02 PM
and then there's the occasional linkage foul up that wont let the throttle open all the way.
