Package Tray Removal/Replace on E-Body? #106582
08/17/08 05:56 PM
08/17/08 05:56 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
I would like to remove the package tray on a 1970 Challenger to be able to install some speakers underneath the tray. I have the proper package tray, but want the screws to be going down to the trunk so they don't show on the package tray itself ( I think this is the stock style?).
My question is -- how do these package trays come out? Mine is still in very good shape so I don't want to damage it. Are they glued in or ?? Is it possible to get these out without damaging them?
Does the backseat back need to come out for this?
Thanks a lot!
--Stan
Re: Package Tray Removal/Replace on E-Body? [Re: stan1970] #106583
08/17/08 08:06 PM
08/17/08 08:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks a lot!
--Stan
Yes take the back seat out and the two rear interior trim panels. Then it should slide right out.
Re: Package Tray Removal/Replace on E-Body? [Re: stan1970] #106584
08/17/08 08:32 PM
08/17/08 08:32 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
If all you want to do is the install speakers, the factory installed the speakers from the trunk side using sheetmetal screws. No need to remove the package tray.
Ron
Re: Package Tray Removal/Replace on E-Body? [Re: Ronnman] #106585
08/17/08 09:12 PM
08/17/08 09:12 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks guys for the help!
My worry about putting screws up from the trunk (to hold the speakers) was that it might puncture the package tray....
What type of screws would one use to mount this from the trunk if you didn't want to poke through the package tray?
Thanks!
Re: Package Tray Removal/Replace on E-Body? [Re: stan1970] #106586
08/17/08 10:56 PM
08/17/08 10:56 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Thanks!
The package shelf needs to come out. You'll need to take out the back seat, remove the 2 interior panels, & slide it out. It is not glued.
Get some machine screws with washers & nuts. From the top, drop the head of the screw thru the metal shelf. Have someone hold the speakers while you get in the trunk & thread on the washers & nuts. Slide the package tray back over the speakers. You're ready to button it up...
I'm assuming that you have the package shelf with the factory slits.
Re: Package Tray Removal/Replace on E-Body? [Re: 318 Stroker] #106587
08/18/08 12:23 PM
08/18/08 12:23 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks all!
Yes, I have the package tray with the speaker grilles, so I should be good on that.
For the backseat -- do both sections need to be removed (i.e. seat bottom and seat back) ? I remember that to get the seat bottom out, you just work it out ...but for the seat back - is this bolted in somehow? I've never tried taking this out.
Thanks again!!
--Stan
Re: Package Tray Removal/Replace on E-Body? [Re: stan1970] #106588
08/18/08 01:21 PM
08/18/08 01:21 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Thanks all!
Thanks again!!
--Stan
Both halves of the back seat have to come out. Remove the bottom bottom 1st. You will then see two screws going thru a u-shaped bracket on the bottom of the back portion of the seat. Remove them & lift up on the seat-back & it comes out very easily...
Re: Package Tray Removal/Replace on E-Body? [Re: 318 Stroker] #106589
08/18/08 02:24 PM
08/18/08 02:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Thanks!
If you use half inch long #8 screws, you can drop the screws in the holes, get in the trunk and put on a couple of nuts to hold it then put a washer, lock washer and nut on the other two. Then go back and put the rest of the hardware on the two you originally put on, a one man job.
Caveat to rear speakers more of a problem on the Road Runners and GTXs is NEVER slam the trunk. I know, no one would do that on purpose but a wind gust or your cousin slamming the trunk can cause enough air pressure to blow the cones out of the magnets on the speakers causing them to distort. The only repair is to replace them.
Craig
Re: Package Tray Removal/Replace on E-Body? [Re: denfireguy] #106590
08/18/08 05:33 PM
08/18/08 05:33 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Stan...If you still have the original 1970 package tray...Follow the previous instructions..But you'll have two metal clips fastened to the bottom of the tray...You need to carefully slide your hand under the tray and pull straight up to release the clips...They look like the lower door panel metal clips....After you remove your seat look under the car's package tray metal frame a few inches front of the speaker holes...You'll see the clips...
Re: Package Tray Removal/Replace on E-Body? [Re: stan1970] #106591
08/20/08 02:17 AM
08/20/08 02:17 AM
I use bolts, nuts and washers to attach the speakers. Just a little insurance.
Also, it's a good idea to lay some screening material over your speakers...nylon screen mesh, speaker grill mesh, old pantyhose etc.
This will keep the dirt and bugs from damaging your speaker cones.
I use some velcro pieces to hold the package tray in place.
