451 or 470 for street/strip car #1065645
08/30/11 08:28 AM
08/30/11 08:28 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Both lowdeck setups which would be better for some street use? Also, does anyone make a rotating assembly for either kit that offers regular rings that do not need to be file fit?
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065646
08/30/11 09:14 AM
08/30/11 09:14 AM
gregsdart Offline
gregsdart  Offline
The best answer is the most cubes you can afford. With cheap cranks available, 499 or 512 low deck combos get my vote. I have run combos of 475, 499, 535, 528, 446. Given the same heads, more cubes for the street is better.
An example, a 535 with standard port heads will have a torque peak of roughly 3800 rpm max, no matter what you do to it.Pretty good rpm for a street combo, never needs more than 6,000 rpm.
A 512 with the same standard port heads will peak around 4,000. The low deck 512 also gives you a very light assembly due to shorter pistons and small rod bearings.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065647
08/30/11 09:26 AM
08/30/11 09:26 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I like my high winding 470.............
Re: 451 or 470 for street/strip car [Re: Thumperdart] #1065648
08/30/11 10:51 AM
08/30/11 10:51 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I'm not interested in running a big stroke in a stock block ever again been there done that 451 or 470 only. Big inches are great but the stock blocks are not.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065649
08/30/11 11:04 AM
08/30/11 11:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m at 11+ years w/two different head/cam combos and I can`t kill this thing and believe me, I`ve tried.
Re: 451 or 470 for street/strip car [Re: Thumperdart] #1065650
08/30/11 11:09 AM
08/30/11 11:09 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I'm a big fan of the 451 and 470. Are there any kits that use non file fit rings?
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065651
08/30/11 11:11 AM
08/30/11 11:11 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... regular rings that do not need to be file fit?
Why bother putting in a good crank / rod / piston assembly and then using "drop in" rings that aren't gap-optimized to seal in the power?
Re: 451 or 470 for street/strip car [Re: BradH] #1065652
08/30/11 11:14 AM
08/30/11 11:14 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed..........it only takes a bit of work or your machinest can fit/file em for ya.
Re: 451 or 470 for street/strip car [Re: Thumperdart] #1065653
08/30/11 11:18 AM
08/30/11 11:18 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
because I have tried it both ways in the past and for what were doing mostly street driving we didn't see any benefit between the two.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065654
08/30/11 11:20 AM
08/30/11 11:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The benefit is knowing EXACTLY where the gaps are taylored to your engine.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065655
08/30/11 11:20 AM
08/30/11 11:20 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
ok...
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 451 or 470 for street/strip car [Re: BradH] #1065656
08/30/11 11:23 AM
08/30/11 11:23 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I like my 451, it works for me and (I think) it has surpassed the goal I originally set for it.
The rest of the car not so much, but it's getting there.
I can understand wanting non-file fit rings, depending on what a person is trying to do....for example if a guy tends to use wider than normal ring gaps for the application anyway, there is no reason to start with no gap at all like a file fit....but I could never find any in a 1/16, 4&3/8 bore. I've deliberately got slightly wider ring gaps than usual in mine just for the safety factor....many would disagree with that practice and that's fine, it works for me.
Rich H.
Esse Quam Videri
Re: 451 or 470 for street/strip car [Re: ZIPPY] #1065657
08/30/11 12:11 PM
08/30/11 12:11 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Too loose is ALWAYS better than too tight. Always.
Re: 451 or 470 for street/strip car [Re: GomangoCuda] #1065658
08/30/11 12:32 PM
08/30/11 12:32 PM
SoCal
Brian Hafliger Offline
SoCal
Not always.... LOL
Brian Hafliger
Re: 451 or 470 for street/strip car [Re: Brian Hafliger] #1065659
08/30/11 12:48 PM
08/30/11 12:48 PM
Not always.... LOL
When it comes to ring gaps, Always. Now if you are talking about what I think you are then I would concur.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065660
08/30/11 02:27 PM
08/30/11 02:27 PM
Bigger is always better, ask for non file to fit rings when you order the kit I would also ask for standard tension oil rings
Re: 451 or 470 for street/strip car [Re: Cab_Burge] #1065661
08/30/11 04:47 PM
08/30/11 04:47 PM
I second Cabs idea on std tension oil rings for the street--I LOVE a 451 CI--I believe it is one of the all time better Mopar combos--they are easy to build--rev like a chainsaw--they don't care what rod length is in there--shelf stock pistons everywhere! Do a 451 and never look back--you will love it!
Re: 451 or 470 for street/strip car [Re: ] #1065662
08/30/11 06:56 PM
08/30/11 06:56 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
What would be the cost difference between a 451" and a 470"?? Ive thought about selling/trading my SB for a 451" or 470"
Re: 451 or 470 for street/strip car [Re: MIKES_DUSTER] #1065663
08/30/11 07:00 PM
08/30/11 07:00 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
451 has a very light rotating assembly. 470 is even lighter using offset ground journals and bb Chevy rods.
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065664
08/30/11 11:26 PM
08/30/11 11:26 PM
IN
ahy Offline
ahy  Offline
IN
On cost, If you have a decent 440 forged crank for a core and a competitive machinist, the 451 made from a 440 crank can be lower cost. Same comment on rods. If you have a good set of standard dimension 440 rods, that favors the 451. The 470 uses a chevy style rod. If you are buying all new, there's little if any cost difference.
They are both good... it comes down to matching heads and picking your power curve. The 451 will want to wind higher than the 470 other things equal.
