Re: 451 or 470 for street/strip car
[Re: DaKuda]
#1065646
08/30/11 09:14 AM
08/30/11 09:14 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The best answer is the most cubes you can afford. With cheap cranks available, 499 or 512 low deck combos get my vote. I have run combos of 475, 499, 535, 528, 446. Given the same heads, more cubes for the street is better. An example, a 535 with standard port heads will have a torque peak of roughly 3800 rpm max, no matter what you do to it.Pretty good rpm for a street combo, never needs more than 6,000 rpm. A 512 with the same standard port heads will peak around 4,000. The low deck 512 also gives you a very light assembly due to shorter pistons and small rod bearings.
[Re: DaKuda]
#1065647
08/30/11 09:26 AM
08/30/11 09:26 AM
Thumperdart
State of confusion
I like my high winding 470.............
[Re: DaKuda]
#1065651
08/30/11 11:11 AM
08/30/11 11:11 AM
BradH
... regular rings that do not need to be file fit?
Why bother putting in a good crank / rod / piston assembly and then using "drop in" rings that aren't gap-optimized to seal in the power?
[Re: DaKuda]
#1065654
08/30/11 11:20 AM
08/30/11 11:20 AM
Thumperdart
State of confusion
The benefit is knowing EXACTLY where the gaps are taylored to your engine.
[Re: BradH]
#1065656
08/30/11 11:23 AM
08/30/11 11:23 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
I like my 451, it works for me and (I think) it has surpassed the goal I originally set for it.
The rest of the car not so much, but it's getting there.
I can understand wanting non-file fit rings, depending on what a person is trying to do....for example if a guy tends to use wider than normal ring gaps for the application anyway, there is no reason to start with no gap at all like a file fit....but I could never find any in a 1/16, 4&3/8 bore. I've deliberately got slightly wider ring gaps than usual in mine just for the safety factor....many would disagree with that practice and that's fine, it works for me.
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#1065661
08/30/11 04:47 PM
08/30/11 04:47 PM
I second Cabs idea on std tension oil rings for the street--I LOVE a 451 CI--I believe it is one of the all time better Mopar combos--they are easy to build--rev like a chainsaw--they don't care what rod length is in there--shelf stock pistons everywhere! Do a 451 and never look back--you will love it!
