'72+ e-body firewall...what are those things? #1065562
08/30/11 02:11 AM
08/30/11 02:11 AM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Always wondered what those two things on the firewall are for???
Re: '72+ e-body firewall...what are those things? [Re: 2fast4yourBrain] #1065563
08/30/11 07:30 AM
08/30/11 07:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC that's the NOX emission system, also found on some 71 Cali cars
Re: '72+ e-body firewall...what are those things? [Re: DAYCLONA] #1065564
08/30/11 08:07 AM
08/30/11 08:07 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
N-95 cars
Re: '72+ e-body firewall...what are those things? [Re: 2fast4yourBrain] #1065565
08/30/11 10:08 AM
08/30/11 10:08 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The device on the left is the temperature control for the EGR valve. It stops pulling exhaust gas through the intake manifold when the engine reaches operating temperature. The one on the right is Oriface Spark Advance Control (OSAC) valve. It limits advance to the distributer until the engine warms up.
Craig
Re: '72+ e-body firewall...what are those things? [Re: denfireguy] #1065566
08/30/11 04:45 PM
08/30/11 04:45 PM
Columbia, Missouri
dtedler Offline
dtedler  Offline
Columbia, Missouri
Look at that photo? Was that a factory location for the coil? I've never seen one mounted that way before.
Re: '72+ e-body firewall...what are those things? [Re: denfireguy] #1065567
08/30/11 05:00 PM
08/30/11 05:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
How sure are you that this is correct?
The EGR control valve (I thought) stopped the EGR valve from opening when the engine was cold. It let the valve open once the engine was up to temp.
I thought I read that the OSAC valve delays the spark advance. Once the throttle is depressed, the spark isn't advanced for 3-5 seconds.
I believe ALL 73 and 74 cars got the OSAC (NOX)valve.(318 and 340/360) In 73 it was mounded on the firewall. In 74 it was moved to the air cleaner.
Only 318's got the EGR control valve.(in 73 at least) 340's didn't get an EGR valve in 73. Please correct me if I'm wrong.
Only early 73's had the temp valve mounted on the firewall. Later cars had it moved somewhere else. Even the 340 cars didn't have that block-off plate on the firewall. That hole wasn't even punched on the later cars.
Re: '72+ e-body firewall...what are those things? [Re: burdar] #1065568
08/30/11 05:11 PM
08/30/11 05:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
http://www.allpar.com/mopar/emissions.html
It says in this link that the NOX valve delays the advance by 15 seconds...not the 3-5 seconds that I posted above.
As far as the smaller EGR control valve, 74's also used a temp valve on the radiator. The one on the firewall must not be temp sensitive but must just delay the vacume signal to the EGR valve.
