Re: 8 3/4 back brace [Re: Guitar Jones] #1065258
08/29/11 11:54 PM
08/29/11 11:54 PM
Canada
CrAzYMoPaRGuY Online content
CrAzYMoPaRGuY  Online Content
Canada
Funny my 4 speed 340 Duster never made a full pass with the 8.75. It was either swap to a Dana or an automatic, I chose the automatic. I have the aluminum center section in mine with a pro gear and have been good to this point but before with a street gear I would plan on a ring and pinion every 2 seasons or so.
I'm on my 5th year on my street gears... still perfect
To the OP... those load bolt just slightly load the
back of the caps (inside) so they are less likely to break
Yeah, your car is probably lighter than mine was but good luck to you.
His car is a heckuva lot faster than yours too !!! My 340 was a second and a half slower than your 340!!
I have had ONE 8 3/4 rear break after 25+ years of very abusive street racing with dozens and dozens of cars.
My Cuda was beaten severely for years and years with the same 4.56 8 3/4 rear. It also had the same A833 tranny. Never had problems with either.
CrAzYMoPaRGuY
Re: 8 3/4 back brace [Re: Guitar Jones] #1065259
08/30/11 12:12 AM
08/30/11 12:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Probably is lighter... heck I got over 600 passes with
a stock pig with a set of 4.88 street gears before
it blew the caps off of it... at that time I changed
over to the alum center with 4.56 street gears running
1.19 - 1.21 60'(depending on how many passes on the slicks)
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065260
08/30/11 12:51 AM
08/30/11 12:51 AM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
Any chance of getting some more info on the jack bolts? Are they just some regular bolts or are they like a jacking screw?
www.racemagnum.com
1954 Plymouth Savoy 2 door
Re: 8 3/4 back brace [Re: lucky13] #1065261
08/30/11 02:09 AM
08/30/11 02:09 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
and are the tubes sealed? i have access to a fantastic fabricator and his shop, he is willing to do whatever i want. he will be installing my cage, wants to build me some super crazy headers... etc... i just need the ideas and how to's to get it going!
Re: 8 3/4 back brace [Re: 8urvette] #1065262
08/30/11 01:13 PM
08/30/11 01:13 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
It's just a threaded spud, you can use a long allen screw or cap bolt, use a jam nut to lock it down just past finger tight. It should hit the center of the caps, prevents them from moving rearward and getting broken or spit out.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: 8 3/4 back brace [Re: Slingshot383] #1065263
08/30/11 02:41 PM
08/30/11 02:41 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
when you install the back brace, make sure you leave room for the shocks. I forgot and the first time the axle rotated up it dented both shocks.
Re: 8 3/4 back brace [Re: larry890] #1065264
08/30/11 02:44 PM
08/30/11 02:44 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
sweet thanks guys, since all i have to pay for is the steel, (and my friend has tons of scrap, literally) it should only be a few bucks, and he will teach me how to do it, so it'll be a good learning experience too!
Re: 8 3/4 back brace [Re: Slingshot383] #1065265
08/30/11 03:09 PM
08/30/11 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its simple to make... I lay it on the back with the
same gap at each end then set my dividers to the gap
then scribe the tubing keep your dividers square to
the axle housing ..... DONT WELD IT ALL AT ONCE
weld 1" sections and jump around so you dont bow the
axle tubes
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065266
08/30/11 05:18 PM
08/30/11 05:18 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
axle tubes
THIS!
Be a builder listen to the guys that know! It will be better than doing nothing!!!
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: 8 3/4 back brace [Re: kilroy] #1065267
08/30/11 06:03 PM
08/30/11 06:03 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
o i know, i have learned this once or twice just welding little stupid things.
and like i said, my friend has been doing welding and fabricating for at least 10 years, owing his own shop, so 12-16 hours a day 7 days a week. you guys know how it is.
the main cap bolt tubes, do they leak then? what size should i use? what grade bolt? and does the threaded pitch matter?
Re: 8 3/4 back brace [Re: kilroy] #1065268
08/30/11 06:06 PM
08/30/11 06:06 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I have to get Mike(P-Body)to put a back brace on my 8.750 in my GTX!...probably next spring,when I get rid of the stock,factory axles!
Re: 8 3/4 back brace [Re: Labratt] #1065269
08/30/11 06:12 PM
08/30/11 06:12 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I dont know why I worry about my 8 3/4 so much if you are running stock axles to low 11's. I like to see that. These 8 3/4's arent as bad as everyone on here says!
67' charger 499 RB 10.57 at 127
Re: 8 3/4 back brace [Re: 8urvette] #1065270
08/30/11 07:36 PM
08/30/11 07:36 PM
Canada
Canada
I bought load bolts from TA who make covers, then modified them to fit my rear. (The car rear people....)
The tubes are welded inside the housing and outside the housing. They shouldn't leak, I don't think the gear oil is filled above their level and I anti-seize the bolts and use a lock nut...
CrAzYMoPaRGuY
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065271
02/23/15 01:23 AM
02/23/15 01:23 AM
Mid-Michigan
GOREO Offline
GOREO  Offline
Mid-Michigan
Mike,
Could you IM me, questions about back bracing for my 8 3/4.
Thanks...
Re: 8 3/4 back brace [Re: 8urvette] #1065272
02/23/15 02:04 AM
02/23/15 02:04 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
here's a pic of mine. was in a trans brake turbo car. 3600 lbs. started shearing pinion gear stems when the car was going hi 9s. Never had failures except for shearing pinion gears.
Re: 8 3/4 back brace [Re: 8urvette] #1065273
02/23/15 03:24 AM
02/23/15 03:24 AM
ky
68roadrunner Offline
ky
Re: 8 3/4 back brace [Re: 8urvette] #1065274
02/26/15 01:30 AM
02/26/15 01:30 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
does anybody have pics of a well made home made brace? I have access to just about everything i could ever need to do this. I am a ok welder at best, but my friend owns a welding fabrication business. He offered me the use of his shop, equipment and expertise... so i figured for the cost of the steel I could make my own. And be well ahead of a stock housing. If any pics are out there i would live to see them!
thank for all the input guys.
A back brace IMO mainly pevents bending of the Housing under extreme acceleration, good traction and High HP applications, and some twisting of same. Does little to help the R&P tooth interface, also IMo the weakest point after
the already mentioned Driver side cap.
Not worth it for OP IMO, and fpllow my suggestion, not what I do.
See pic #43 https://board.moparts.org/ubbthreads/show...part=1&vc=1
