8 3/4 back brace #1065238
08/29/11 06:18 PM
08/29/11 06:18 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I know this has been beaten to death about what power will a 8 3/4 take, but i have a question about how much strength a back brace will add to it.
i have a 68 cuda rb stroker 543 with a 4 speed, 8 3/4 with 3.23 and a 3.91 center chunk. If i back brace my housing and don't launch hard will this rear end live for any amount of time? I have small street licks so i don't imagine ill have much traction, but i ran out of funds so my dana will have to wait till taxes.... does anyone know if a homemade back brace will add enough strength to the lil guy to make it last a few months??? no power shifting, easy launches, and my throttle cable only gets me about 60% throttle, so that should help too!!!
Is it realistic to expect it to live? mainly street driving.
Re: 8 3/4 back brace [Re: 8urvette] #1065239
08/29/11 06:31 PM
08/29/11 06:31 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
IMO, if you are just street driving and not beating on the car. You don't even need the back brace. If you are taking it to the track Then I'd think about beefing it up. Start with billet caps (this is the weakest point), then move on to back bracing the rear. The back brace will add much needed strength so the housing doesn't twist now that the caps won't break
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 8 3/4 back brace [Re: 8urvette] #1065240
08/29/11 06:40 PM
08/29/11 06:40 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I am an 8 3/4 fan .. but I say NO to any 4 speed car with a decent hook.
PLUS ...if you try adding a brace now .. it could move-around the housing so the bearing races could jam-up.
I say save your $$$ for the Dana.
Re: 8 3/4 back brace [Re: DemonDust] #1065241
08/29/11 07:18 PM
08/29/11 07:18 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Pluss you might have clearance issues with the brace in the way of the fuel tank. I know a Dana is close, and most guys have to "clearance" the tank .
I think an 8.75 will hold up for a while, are you an auto or stick cause IMHO thik that makes a difference also.
Sorry just read its a 4 gear, so I guess ya better brace or upgrade.
Kasey
Re: 8 3/4 back brace [Re: Moparnut426] #1065242
08/29/11 07:27 PM
08/29/11 07:27 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Depends how grabby your clutch is. If you have something like a centerforce, you'll be driving over your driveshaft at some point. If you do baby the car on the street, it will be okay until you upgrade, but don't dump the clutch (feather it out only), no burnouts, and no powershifting. Or, just put junk street tires on it that won't hook, you'll be fine on them.
The brace won't help you any, either. It's not worth the effort.
Re: 8 3/4 back brace [Re: Blusmbl] #1065243
08/29/11 07:43 PM
08/29/11 07:43 PM
Guitar Jones Offline
Re: 8 3/4 back brace [Re: 8urvette] #1065244
08/29/11 07:47 PM
08/29/11 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As for the back brace it helps ALOT... the ends of the
housing are trying to bend forwards if it has any bite
at all... I've seen and fixed many with bent axle tubes...
I would also invest in the caps... 4 speeds are hard
on the 8 3/4 but there were PLENTY of cars that came
with the 8 3/4, including 4 speeds but with the brace
and caps it will help alot... can you still break it...
sure you can(and you can break a dana also)... everything
has a breaking point.... now days if I narrow a 8 3/4
for a customer I always suggest the back brace
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065245
08/29/11 08:57 PM
08/29/11 08:57 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I probably should've clarified. I agree, the back brace does help, especially for the axle shafts themselves. However, I don't think they'd help at all in this situation, with the common shock loading failure that a 4 speed adds to the equation- I'd guess it is more likely to break the pinion or ring gear than the axles.
They lived behind 383 4 speed B bodies on street tires. It certainly is not going to live behind a 543" RB 4 speed with a street friendly clutch and cheater slicks. The money spent on a backbrace and axle caps should be saved and applied to a Dana or 9". If you can make one on your own for little/no investment, it's not going to hurt anything, but I wouldn't put any faith in it either.
I tried to make my 8 3/4 live in my Charger, as soon as I put decent tires on the car it spit out a ton of rearend parts. U joints, a pinion (in half- not missing teeth), axle (on a drag radial, cutting stellar 2.0 60's at Milan), etc. I never broke a ring gear, but I'd imagine with any more power it would've been next.
Re: 8 3/4 back brace [Re: Blusmbl] #1065246
08/29/11 09:28 PM
08/29/11 09:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Based on the info he gave it wont have a problem
Re: 8 3/4 back brace [Re: Blusmbl] #1065247
08/29/11 09:29 PM
08/29/11 09:29 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
does anybody have pics of a well made home made brace? I have access to just about everything i could ever need to do this. I am a ok welder at best, but my friend owns a welding fabrication business. He offered me the use of his shop, equipment and expertise... so i figured for the cost of the steel I could make my own. And be well ahead of a stock housing. If any pics are out there i would live to see them!
thank for all the input guys.
The rear end was originally bought and narrowed when i went to a from a stock smogged down 360 to a semi built 383 727 combo.
Re: 8 3/4 back brace [Re: 8urvette] #1065248
08/29/11 09:37 PM
08/29/11 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have one on my 8 3/4 but its sorta hard to see and
I have one on my 9" thats easier to see.... same thing
basically 2" X 3" rectangular tubing
this first one is my 8 3/4
Re: 8 3/4 back brace [Re: 8urvette] #1065249
08/29/11 09:38 PM
08/29/11 09:38 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Im an advocate of 8 3/4 but with a 4 speed...no way thats why all hemi 4 speeds had a dana
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065250
08/29/11 09:40 PM
08/29/11 09:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the 9"
Re: 8 3/4 back brace [Re: 8urvette] #1065251
08/29/11 09:59 PM
08/29/11 09:59 PM
Canada
CrAzYMoPaRGuY Offline
Canada
1968 340 4 speed Barracuda, 4.56 gears, beaten to death street racing over a 10 year span.... 8 3/4 rear with stock caps and NO back brace. Never had any rear end problems whatsoever.
This is what I did for my Coupe, after destroying a half dozen ferd 9" rear centers in my Demon... with a HYDRAULIC CAMMED 440... I swore never again a 9".
I backbraced my housing with load bolt provisions and MW caps. I'm 650hp with 2900 pounds. If it breaks it breaks, but I'm confident it won't, and have no problem trying other solutions if it does.
I had a 500ish hp 440 in the same car for YEARS and YEARS with a non-braced 8 3/4, never had any trouble with it either. Beat the car on a daily basis.
New setup...
CrAzYMoPaRGuY
Re: 8 3/4 back brace [Re: Blusmbl] #1065252
08/29/11 10:01 PM
08/29/11 10:01 PM
I still agree, I personally wouldn't expend the effort to back brace the 8.75 in your application. I don't think it's going to help anything. If you get the tires to hook you are going to have way more problems than a backbrace can solve. So why bother? Just baby it and save your money for a Dana.
Re: 8 3/4 back brace [Re: CrAzYMoPaRGuY] #1065253
08/29/11 10:05 PM
08/29/11 10:05 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
crazymoparguy- what are the load bolt provisions?
Re: 8 3/4 back brace [Re: CrAzYMoPaRGuY] #1065254
08/29/11 10:05 PM
08/29/11 10:05 PM
Funny my 4 speed 340 Duster never made a full pass with the 8.75. It was either swap to a Dana or an automatic, I chose the automatic. I have the aluminum center section in mine with a pro gear and have been good to this point but before with a street gear I would plan on a ring and pinion every 2 seasons or so.
Re: 8 3/4 back brace [Re: Guitar Jones] #1065255
08/29/11 10:14 PM
08/29/11 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm on my 5th year on my street gears... still perfect
To the OP... those load bolt just slightly load the
back of the caps (inside) so they are less likely to break
Re: 8 3/4 back brace [Re: MR_P_BODY] #1065256
08/29/11 10:18 PM
08/29/11 10:18 PM
Yeah, your car is probably lighter than mine was but good luck to you.
Re: 8 3/4 back brace [Re: 8urvette] #1065257
08/29/11 11:50 PM
08/29/11 11:50 PM
Canada
Canada
Threaded tubes which allow a load bolt to be theaded up to the back of the caps.
I think a few companies make rear end covers for Dana 60s that do the same thing.
CrAzYMoPaRGuY
