47RE stuck in 1st gear....***SOLVED*** #1064865
08/28/11 11:50 PM
08/28/11 11:50 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Feeling stupid here but don't know what model AUTOMATIC Trans I have in my '99 Dodge Ram with a 5.9 Cummins.
46re? 48re?
Having issues and need some
Please enlightene me
Re: What Transmission do I have??? [Re: roadhazard] #1064866
08/29/11 01:29 AM
08/29/11 01:29 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
46RE if its original
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: What Transmission do I have??? [Re: roadhazard] #1064867
08/29/11 09:28 AM
08/29/11 09:28 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
No, you have a 47 RE!!
what issues are you having?
Re: What Transmission do I have??? [Re: fox] #1064868
08/29/11 09:59 AM
08/29/11 09:59 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
47RE it is then. Truck is all original with 92K on it. No mods and lived an easy life by the previous owner. Previous owner had aslo claimed to have changed the fluid & filter.
It was holding 1st gear too long when you initially took off in Drive. It seemed like it would shift after you travled 125' or so. After that it would shift normal without holding 1st.
Yesterday it would not shift out of 1st at all no matter what
Does the APPS (TPS) control the trans shift at all? I had an APPS issue and adjusted it slightly by eye and that took care of my sudden intermittent "no throttle" problem.
I will go out today and see if I can adjust the APPS properly with a meter & see what happens
Appreciate any and all help on this one
Re: What Transmission do I have??? [Re: roadhazard] #1064869
08/29/11 03:26 PM
08/29/11 03:26 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Well I adjusted the APPS to spec and no luck
Still stuck in 1st gear
Read something on another forum about the Govenor Pressure sensor and solenoid/transducer causing this issue.
Your thoughts?
Re: What Transmission do I have??? [Re: roadhazard] #1064870
08/29/11 04:13 PM
08/29/11 04:13 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
how many miles on it? i would check all the fuses, also swap the trans relay with the ac one or something, if that doesnt work, get a new output speed sensor, if thats not it you probably need new electronics in the transmission. 47re's are great, i have one behind my 02 2500 that just dyno'ed at 550 hp and maxed out the tq reading, and thats in street trim. Guess what, its all on stock clutches and being abused for over 60k miles.
Re: What Transmission do I have??? [Re: ditchdrift] #1064871
08/29/11 06:17 PM
08/29/11 06:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the only thing electronic about the 47re is the governor pressure solenoid and sensor and the solenoids that control lockup clutch application and OD application.
The pressure sensor and solenoid are known problems, start there first .
Re: What Transmission do I have??? [Re: JohnRR] #1064872
08/29/11 06:58 PM
08/29/11 06:58 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
I had a Plymouth Breeze that had a speed sensor go bad and it only had first and reverse. It had two sensors, input and output speed on the transmission. My understanding is that if either of these sensors go bad it will not shift out of first gear. Just a thought.
Russ:)
BigBlock 74 Swinger
Re: What Transmission do I have??? [Re: bb74swngr] #1064873
08/29/11 07:15 PM
08/29/11 07:15 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
could be front band or kickdown band mine went bad and it would only shift to second when let off of gas
Re: What Transmission do I have??? [Re: d-150] #1064874
08/29/11 07:26 PM
08/29/11 07:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ck the output speed sensor on the tail shaft.
I just re-built mine last week for a lost OD clutch and this weekend off and on it wanted to delay upshifts, especially the 1 - 2 shift
went out this afternoon and no upshift what so ever. changed the speed sensor and all is good
Re: What Transmission do I have??? [Re: gtx6970] #1064875
08/29/11 08:52 PM
08/29/11 08:52 PM
JohnRR Offline
JohnRR  Offline
bill what year is your truck ? I'm pretty sure the 98 I owned had one , I don't think my 2000 has one ? 99 ????
Re: What Transmission do I have??? [Re: JohnRR] #1064876
08/29/11 09:01 PM
08/29/11 09:01 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
I had that problem with my 46RE!
Re: What Transmission do I have??? [Re: JohnRR] #1064877
08/29/11 09:43 PM
08/29/11 09:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2000 Dodge Ram 2500 5.9 gas motor - same output speed sensor as the 604 based ft wheel drive cars
Re: What Transmission do I have??? [Re: gtx6970] #1064878
08/29/11 11:24 PM
08/29/11 11:24 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
The sensor depending on what it costs would be wise to try, but I honestly think the front band might have went.
It's possible it wore out and the band anchor fell out and dropped into the pan leaving the band hanging in despair.
If the band isnt worn you can put it back in and adjust it, but usually that happening is a sign the band is gone.
If it is gone, the trans has to come out to replace it and you might as well rebuild the whole thing at that point since it has to come apart anyway. The front pump has to be removed to get to it.
If you decide to rebuild it, have someone here do it if you can.
You'll get a lot better deal and some of the trans shops out there are complete crooks.
I ended up swapping a 727 into my dakota because I hate the 46re.
Electronics are junk IMO.
Re: What Transmission do I have??? [Re: POS Dakota] #1064879
08/30/11 01:03 AM
08/30/11 01:03 AM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
if it were the intermediate band you would upshift to 3rd at about 35- 40 mph and feel like you are freewheeling in between . it sounds like a gov solenoid and sensor problem , get a scanner on it and look at sensor readings instead of throwing parts at it
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: What Transmission do I have??? [Re: jwilson 61] #1064880
08/30/11 02:43 AM
08/30/11 02:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
First scan it for codes. It only has one speed sensor which is the output shaft speed sensor that tells the PCM the output shaft speed so it can work the gov solenoid. If that sensor is bad it may not shift. We have had alot of problems with the gov solenoids and sensors. As was said if the front band was broke it would just stay in first until enough road speed (from 15 to 25 or so) then shift into third. No shifting at all either the throttle pressure lever is stuck wide open or the gov solenoid and press sensor are bad most likely. But I would scan it for codes first. Ron
Re: What Transmission do I have??? [Re: bb74swngr] #1064881
08/30/11 04:33 PM
08/30/11 04:33 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Russ:)
This also on a 99 dakota. Sounds similar to your problem.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: 47RE Stuck in First Gear *** SOLVED*** [Re: kilroy] #1064882
09/05/11 10:05 AM
09/05/11 10:05 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
First I'd like to thank you ALL for your help and imput
Had to take the truck to "The Man" aka tranz shop as it's my driver. Didn't want to just start replacing parts without knowing for sure what it was and time was not on my side.
Ended up it was the speed sensor and some corroded connections
There has to be some way to check this with a meter, no
Not too hateful so I had them do a fluid flush, filter change and adjust the bands while the pan was off.
By the way the pan was real clean inside so I was told
Thanks again all, Greg
Re: 47RE Stuck in First Gear *** SOLVED*** [Re: roadhazard] #1064883
09/05/11 04:54 PM
09/05/11 04:54 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
there is, take the speed sensor out and put an ohm meter on it. spin the speed sensor, if you get a reading it should be ok. No reading would be dead sensor.
Re: 47RE Stuck in First Gear *** SOLVED*** [Re: kilroy] #1064884
09/05/11 06:11 PM
09/05/11 06:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can't "spin" the speed sensor on an RE, it's just a magnetic pickup that uses the park gear cogs as a reluctor.
