47RE stuck in 1st gear....***SOLVED***
#1064865
08/28/11 11:50 PM
08/28/11 11:50 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Feeling stupid here but don't know what model AUTOMATIC Trans I have in my '99 Dodge Ram with a 5.9 Cummins. 46re? 48re? Having issues and need some Please enlightene me
Re: What Transmission do I have???
[Re: roadhazard]
#1064867
08/29/11 09:28 AM
08/29/11 09:28 AM
Posts: 541 chatham, Ilinois
fox
super street
super street
chatham, Ilinois
No, you have a 47 RE!! what issues are you having?
[Re: roadhazard]
#1064869
08/29/11 03:26 PM
08/29/11 03:26 PM
roadhazard
Akron, Ohio U.S.A.
Well I adjusted the APPS to spec and no luck Still stuck in 1st gear Read something on another forum about the Govenor Pressure sensor and solenoid/transducer causing this issue. Your thoughts?
[Re: JohnRR]
#1064872
08/29/11 06:58 PM
08/29/11 06:58 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
I had a Plymouth Breeze that had a speed sensor go bad and it only had first and reverse. It had two sensors, input and output speed on the transmission. My understanding is that if either of these sensors go bad it will not shift out of first gear. Just a thought. Russ:)
BigBlock 74 Swinger
[Re: gtx6970]
#1064875
08/29/11 08:52 PM
08/29/11 08:52 PM
Posts: 74,969 U.S.S.A.
JohnRR
U.S.S.A.
ck the output speed sensor on the tail shaft.
I just re-built mine last week for a lost OD clutch and this weekend off and on it wanted to delay upshifts, especially the 1 - 2 shift
went out this afternoon and no upshift what so ever. changed the speed sensor and all is good
bill what year is your truck ? I'm pretty sure the 98 I owned had one , I don't think my 2000 has one ? 99 ????
[Re: JohnRR]
#1064876
08/29/11 09:01 PM
08/29/11 09:01 PM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
the only thing electronic about the 47re is the governor pressure solenoid and sensor and the solenoids that control lockup clutch application and OD application.
The pressure sensor and solenoid are known problems, start there first .
I had that problem with my 46RE!
[Re: JohnRR]
#1064877
08/29/11 09:43 PM
08/29/11 09:43 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
2000 Dodge Ram 2500 5.9 gas motor - same output speed sensor as the 604 based ft wheel drive cars
[Re: POS Dakota]
#1064879
08/30/11 01:03 AM
08/30/11 01:03 AM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
if it were the intermediate band you would upshift to 3rd at about 35- 40 mph and feel like you are freewheeling in between . it sounds like a gov solenoid and sensor problem , get a scanner on it and look at sensor readings instead of throwing parts at it
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: jwilson 61]
#1064880
08/30/11 02:43 AM
08/30/11 02:43 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
First scan it for codes. It only has one speed sensor which is the output shaft speed sensor that tells the PCM the output shaft speed so it can work the gov solenoid. If that sensor is bad it may not shift. We have had alot of problems with the gov solenoids and sensors. As was said if the front band was broke it would just stay in first until enough road speed (from 15 to 25 or so) then shift into third. No shifting at all either the throttle pressure lever is stuck wide open or the gov solenoid and press sensor are bad most likely. But I would scan it for codes first. Ron
Re: 47RE Stuck in First Gear *** SOLVED***
[Re: kilroy]
#1064882
09/05/11 10:05 AM
09/05/11 10:05 AM
roadhazard
Akron, Ohio U.S.A.
First I'd like to thank you ALL for your help and imput Had to take the truck to "The Man" aka tranz shop as it's my driver. Didn't want to just start replacing parts without knowing for sure what it was and time was not on my side. Ended up it was the speed sensor and some corroded connections There has to be some way to check this with a meter, no Not too hateful so I had them do a fluid flush, filter change and adjust the bands while the pan was off. By the way the pan was real clean inside so I was told Thanks again all, Greg
[Re: kilroy]
#1064884
09/05/11 06:11 PM
09/05/11 06:11 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You can't "spin" the speed sensor on an RE, it's just a magnetic pickup that uses the park gear cogs as a reluctor.
