Wiper fiasco continues.... #1064443
08/28/11 01:23 PM
08/28/11 01:23 PM
USA
ramairthree Offline OP
USA
well,
I got my wipers assembled and ready to roll.
Issues are- the motor does not want to pull the wipers down past the bottom trim to park. It trys, but can't.
-if these are hideaway wipers, they do not fit between the back of the hood and the cowl, the space is too tight.
i thought I had adusted to where park put them just above the trim, but nope.
these look to be the right wiper arms in the manual, so problems could be:
aftermarket windshield is shaped a little off
poor trim fit makes it a touch too tall
replacement wiper blades are too tall
any hints appreciated.
Re: Wiper fiasco continues.... [Re: ramairthree] #1064444
08/28/11 01:45 PM
08/28/11 01:45 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Need more info. What make, model, year?
A pic or two would help us help you, too.
Re: Wiper fiasco continues.... [Re: ramairthree] #1064445
08/28/11 02:08 PM
08/28/11 02:08 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Getting that stainless trim to fit close to the the windshield right is a PITA. That's what my wipers hung up on on my '72. Don't know how to adjust the "fit" without dorking up the bottom window trim.
Also, if the wiper refill is least bit weak/worn out/soft, it will fold over some and the refill clips will hang on the edge of the trim.
If they don't fit under the hood, my guess would be warped hood rather than misfitting glass.
Re: Wiper fiasco continues.... [Re: In_The_Pink] #1064446
08/28/11 02:35 PM
08/28/11 02:35 PM
USA
USA
thanks, 1974 Roadrunner
looks like the correct wiper blades
I have the correct wiper motor arm for a two speed
passenger side linkage nut was not on tight enough, and it came off as the motor tried to pull it down past the bottom trim
you can see how the wiper arm, let alone with blade, will not fit between trim and hood
driver's side is the same
Aside from the fit,
I am having trouble getting the passenger linkage arm nut popped on tight enough. I remvoved the drivers side to do that one, but when I hit the release lever on the passenger the lever came off and arm stuck on pivot.
I am having trouble getting the linkage arm to motor attachement. The shape of the opening is supposed to fit square with the nut/post but not able to get it.
Some of the issues you see are the linaage arm popped off the passenger wiper, and the wiper linkage slipping on the motor stud.
But, big problem for me is no matter how I put on the wiper arm when it is in park, the travel wants to come below the bottom trim, but it catches there.
Re: Wiper fiasco continues.... [Re: ramairthree] #1064447
08/28/11 02:45 PM
08/28/11 02:45 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
First off...Those aftermarket wiper assemblies definitely sit higher than the factory pieces... How does the wiper motor work in general ??? Sluggish ??? Battery fully charged ???
Re: Wiper fiasco continues.... [Re: ramairthree] #1064448
08/28/11 02:45 PM
08/28/11 02:45 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I believe the arms are the same for both 2 and 3 speed wipers. It appears the height on the aftermarket blades is causing the issue. Here are oem blades and they are much shorter allowing the blade to clear the hood.
Re: Wiper fiasco continues.... [Re: T2R9] #1064449
08/28/11 03:05 PM
08/28/11 03:05 PM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
Agreed, ditch those aftermarket blades, just too thick and bulky causing clearance issues, not to mention twice the weight causing the motor to strain. Doesn't look like the trim is flush with the windsheild either.
Re: Wiper fiasco continues.... [Re: lakerism] #1064450
08/28/11 03:08 PM
08/28/11 03:08 PM
USA
USA
yep, I cannot get the trim to flush with the glass.
This was aftermarket glass.
I have one of the trico blades, let me see how that compares...
Re: Wiper fiasco continues.... [Re: ramairthree] #1064451
08/28/11 03:53 PM
08/28/11 03:53 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
As mentioned, the pivot point on the newer blade holders you have installed are too high. I suggest you find some original blade holders and install the original style blades available from NAPA.
Re: Wiper fiasco continues.... [Re: In_The_Pink] #1064452
08/28/11 04:26 PM
08/28/11 04:26 PM
USA
USA
ok, a trico "tru fit / exact fit" blade holder bought me 1/8 to 1/4 lower height.
Between the trim being so high off the glass,
and also noted my hood alligns about 1/8 inch too far to the rear, but no room up front to adjust. (that's what you get buyin a stalled project before it gets scrapped)
Thanks for all the tips, I am close
Re: Wiper fiasco continues.... [Re: ramairthree] #1064453
08/29/11 08:51 PM
08/29/11 08:51 PM
USA
USA
ok, I pulled everything.
I assembled my linkage outside of the cowl.
It is just like in the picture.
http://www.dodgecharger.com/forum/index.php/topic,23779.0.html
I reinstalled wihtout putting the wiper arms back on.
Something seemed to be catching, and some smoke started coming from the motor or resistor.
Running just the driver's side blade the other day without being hooked up to the passenger pivot arm did not do that.
I -thought- the pivot arms could only fit on one way.
Is there some hint to their alignment?
Thanks for any more info.
I was all happy everything was hooked up and was ready to put the arms on.
Obviously kind of bummed when that happend.
I have pulled the linkage again.
