thanks, 1974 Roadrunner
looks like the correct wiper blades
I have the correct wiper motor arm for a two speed
passenger side linkage nut was not on tight enough, and it came off as the motor tried to pull it down past the bottom trim
you can see how the wiper arm, let alone with blade, will not fit between trim and hood
driver's side is the same
Aside from the fit,
I am having trouble getting the passenger linkage arm nut popped on tight enough. I remvoved the drivers side to do that one, but when I hit the release lever on the passenger the lever came off and arm stuck on pivot.
I am having trouble getting the linkage arm to motor attachement. The shape of the opening is supposed to fit square with the nut/post but not able to get it.
Some of the issues you see are the linaage arm popped off the passenger wiper, and the wiper linkage slipping on the motor stud.
But, big problem for me is no matter how I put on the wiper arm when it is in park, the travel wants to come below the bottom trim, but it catches there.
