Re: These valve covers WILL NOT seal [Re: TRENDZ] #1064369
08/29/11 05:55 PM
08/29/11 05:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Iron bb heads valve cover rails are not flat. They are not supposed to be. The threaded holes are not square to the surface, they are tipped toward the intake side of the engine on purpous, as are the bosses they are drilled into. I'm very supprized you were able to get bolts in at all. If you put a straight edge on the thread bosses and compare that height to the front and the rear rails, you wil find about 1/8" difference. Those covers were meant for aftermarket heads. All of the aftermarket heads I know of have flat valve cover rails.
THIS
Re: These valve covers WILL NOT seal [Re: JohnRR] #1064370
08/29/11 06:49 PM
08/29/11 06:49 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Cork gaskets All the local auto stores around here try to push the rubber ones but I have always had problems with them....
Re: These valve covers WILL NOT seal [Re: SLOW67] #1064371
08/29/11 07:42 PM
08/29/11 07:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
The covers are clearing the rockers and everything, and the bolts are all the correct length. I may have to sell these covers and get some that are designed more for iron stock heads.
Last night I even bought the $38 Moroso's with the steel shim and the soft blue rubber and the passenger side still leaks.
The covers are not very flat but seem flat enough to work with a good gasket.
Does anyone know the part number for the thick cork gaskets? I've already tried the thin ones glued to the valve cover with grease on the head and it leaked, then I tried tightening it more and it cut the gasket in half.
I've raced for 23 years and have never had something this small keep my car down for a week, unbelievable.
Also, I need to find someone local with a belt sander to flatten these covers.
Re: These valve covers WILL NOT seal [Re: ProSport] #1064372
08/29/11 07:58 PM
08/29/11 07:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
Well I have the same trouble with my car ..but the heads and the valve cover are the other way around.Eddy heads and old style cast alum valve covers. The angle of the new style heads and old style valve cover do not match.When you tighten the bolts down it pull them down wrong. I have try'ed everything and I come to realize that I need to buy a new style valve cover. so if you want to trade with some boot money let me know ! LOL I don't think my red ones would look good on your yellow car. they are power coated..but you could bast them and change the color..
Re: These valve covers WILL NOT seal [Re: VernMotor] #1064373
08/29/11 08:16 PM
08/29/11 08:16 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Vern I would just sell yours and buy the 440source covers, they are only $119 fully polished and you can use studs and nuts instead of these long bolts that are eventually gonna strip out the holes in the heads. I hate these covers. They look nice though.
Re: These valve covers WILL NOT seal [Re: ProSport] #1064374
08/29/11 08:33 PM
08/29/11 08:33 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I use yellow 3M adhesive to glue the gaskets to the covers...and I use no RTV at all.
Re: These valve covers WILL NOT seal [Re: ProSport] #1064375
08/29/11 09:05 PM
08/29/11 09:05 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
It's hard to make a non-level surface level just with a belt sander. If you have a flat surface available like a butcher's block or thick piece of glass, tape large pieces of sandpaper to it and use the surface to sand the valve cover rail area down. I've done this on water necks and other items, it works much better than the belt sander.
I'll also go against the grain and mention I've had much better luck with rubber gaskets vs. cork, but that could just be operator error on my end.
Re: These valve covers WILL NOT seal [Re: Blusmbl] #1064376
08/29/11 10:18 PM
08/29/11 10:18 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Has anybody found a part number for the thick cork gaskets? I can't seem to find any that say 'thick'. Flatout makes some that are .060 but that doesn't seem very thick.
Also, if I do have to buy new covers, which nice aluminum ones fit stock iron type heads? Is it just the $149 Mopar Performance ones.
Re: These valve covers WILL NOT seal [Re: ProSport] #1064377
08/29/11 10:32 PM
08/29/11 10:32 PM
rising sun, maryland
fastcoronet Offline
fastcoronet  Offline
i have the same valve covers, and they would not seal no matter what i did. turn the valve cover over and put a straight edge on the rail where the welds were ground from the manufacture. you will see that the weld is still high and it is not letting the valve cover to seal along the center of the valve cover. I had to take a hand file and file the welds down to match the ends and the center of the valve cover. the center of the covers are a one piece formed alum. and the ends are another formed piece and where the two formed pieces were welded together along the rail is the problem. once i files this area they never leak again.
Re: These valve covers WILL NOT seal [Re: fastcoronet] #1064378
08/29/11 10:36 PM
08/29/11 10:36 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I noticed the same thing, I filed all the high spots and found 2 screws that were too long, thought for sure it was gonna seal this time but nope.
I might try to do some more filing tomorrow, I know it's not perfect.
By the way, who makes these covers and what do they cost?
Re: These valve covers WILL NOT seal [Re: ProSport] #1064379
08/30/11 10:45 PM
08/30/11 10:45 PM
fastcoronet Offline
fastcoronet  Offline
mine were by Summit and they cost around 250.00
I feel Summit stop selling them because of the non sealing problems. Once I got the welds flat I had to buy new bolts I went with Stainless. I have them on and off now for 6 years ateast.
Re: These valve covers WILL NOT seal [Re: fishy340] #1064380
08/31/11 10:21 PM
08/31/11 10:21 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Gey the Magnum vc......worth every penny !
Dan
Re: These valve covers WILL NOT seal [Re: ProSport] #1064381
09/01/11 12:35 AM
09/01/11 12:35 AM
ccarson Offline
ccarson  Offline
I have the same ones they will seal if their flat, I set them up on the bridgeport and took a cut.
I also used the Moroso gaskets with the steel shim, those had to be modified to clear the pushrods on 59 Deg W9 Heads.
Re: These valve covers WILL NOT seal [Re: ccarson] #1064382
09/01/11 08:39 AM
09/01/11 08:39 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
trie once Cometic gaskets and forget those oil leaks
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
