mini starter #1064061
08/27/11 10:32 PM
08/27/11 10:32 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
whats the best starter out there for a big block
thank's guys
Re: mini starter [Re: MOPARCHAS] #1064062
08/27/11 11:07 PM
08/27/11 11:07 PM
scratchnfotraction Offline
I run a stock mini starter from a 92 DAK 5.2 engine on my 440
if you go newer yr watch for the plug change,97 or so IIRC
some have a extention piece you remove to use the studs right off the starter.
my last 2 have been U-pull it speicals for 14$
Re: mini starter [Re: scratchnfotraction] #1064063
08/28/11 03:27 AM
08/28/11 03:27 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
powermaster ultra here.rolls my 16to1 mill over easy.
Re: mini starter [Re: boatracer572] #1064064
08/28/11 09:42 AM
08/28/11 09:42 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
16 to 1?
Re: mini starter [Re: scratchnfotraction] #1064065
08/28/11 11:42 AM
08/28/11 11:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use the stock Chrysler mini starter... been
in there for years.... I'll use the same thing on
my new engine
Re: mini starter [Re: scratchnfotraction] #1064066
08/28/11 01:10 PM
08/28/11 01:10 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Just installed a 98 1500 truck starter on mine. It needed a new starter anyway and I was tired of wrestling my heavy stock unit. I had to enlarge the hole in the stock solenoid wire just a tad with a file but everything else went on like stock
Re: mini starter [Re: boatracer572] #1064067
08/28/11 09:40 PM
08/28/11 09:40 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Send it back to them,,,,let them check it over REAL good...then,, MAYBE,, they can duplicate it and someone else can have a good one too.
If you like drag racing, support your local track.
Re: mini starter [Re: CHAPPER] #1064068
08/29/11 07:12 AM
08/29/11 07:12 AM
pa
572charger Offline
572charger  Offline
pa
89 dodge truck starter in mine![mini] cost 85 dollars at advance auto in 2003 still turning over my 606 cuin hemi don't let them starter companys fool u lot of them slap their stickers on a stock starter an charge ya 3 time the cost !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: mini starter [Re: 572charger] #1064069
08/29/11 12:43 PM
08/29/11 12:43 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
I run a stock mopar starter AND A 16 VOLT BATTERY SYSTEM on my 500-plus
all alum b-1 motor with 17-1 compression---
i had problems with the 12 volt system for 2 years--went thru 3 big batteries---thinking it was the starter--and all this time it was the 12 volt battery--not beeing enough
i went to jegs--got the kinetic 16 volt battery and X-POWER charger
LOVE IT---wish someone would have told me this 2 years ago
ross
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
