7000 rpm 440 #1063937
08/27/11 02:04 PM
08/27/11 02:04 PM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
building a new 440 this fall
don't want a stroker
looking for a streetable 7000rpm
what valve train do you all run
full roller cam specs
eddy heads ???
going to try fuel injection
running stock forged crank
any help
thanks to all
Mike
Re: 7000 rpm 440 [Re: smracing] #1063938
08/27/11 02:30 PM
08/27/11 02:30 PM
I've had a lot of stock stroke Mopar RB bracket motors that I shifted at or near 7000 RPM, not all of them pulled hard above 6400 RPM though My current pump gas street motor (518 C.I.) has Indy SR heads with Max Wedge ports with T&D single shaft 1.65 rocker assembly, a Indy 400-3 intake and a Holley 1050 Dominator. This combination pulls really hard to 7000 + RPM I have ran a set of Eddy RPM standard 440 port that where CNC ported by Modern Cylinder heads, I ran a low deck six pak intake and stock type Holley vacume carbs, that combination would pull hard in 1st and 2nd gear to above 7000 RPM also but it did not pull hard above 6200 RPM in high gear It has a set of Harland Sharp 1.6 ratio roller rockers, both top end set ups used the same short block and cam The cam is a Comp Cams solid roller that is 260 at .050 on the intake and 266 on the exhaust with right at .700 net lift at the retainers. I never tried a single plane four barrel intake in the car with those Eddy heads so I would think that a good single plane intake and 850 + CFM carb would pull hard to 7000 + with the right cam grind IHTHs
Re: 7000 rpm 440 [Re: Cab_Burge] #1063939
08/27/11 02:54 PM
08/27/11 02:54 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Mine goes 7200 thru the traps, iron 906 heads with Crane rockers, Mopar 590 cam & springs, Ferrara valves. Best thing to do is get lightweight h-beam rods and pistons. I got mine from Muscle Motors, 260 runs on this combo and no problems.
Re: 7000 rpm 440 [Re: cgall] #1063940
08/27/11 03:11 PM
08/27/11 03:11 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What time does yours run, i run the .590 and shift at 6200, trap at 6500.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 7000 rpm 440 [Re: deaks] #1063941
08/27/11 03:20 PM
08/27/11 03:20 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
10.20's in good air, 10.40's in Ohio summertime. Car is light, only 2850 with driver.
Re: 7000 rpm 440 [Re: deaks] #1063942
08/27/11 03:59 PM
08/27/11 03:59 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Wow, mine's 3200 with me, must be well stripped out.
To the op, a previous thread
https://board.moparts.org/ubbthreads/show...part=1&vc=1
