Wheel Vintiques issue #1063553
08/26/11 10:00 PM
08/26/11 10:00 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Just received wheeles from wheel vintiques. I ordered 15 inch wheel(cop wheel) with a 4.5" backspace. I measured one wheel and backspace is 4 13/16, not 4.5". Has anyone else ever run into this with Wheel Vintique wheeles? Would 5/16 make that much difference? Car is 69 GTX 275-60-15 and 245-60-15 tires. Your thoughts?
Re: Wheel Vintiques issue [Re: frank] #1063554
08/26/11 11:49 PM
08/26/11 11:49 PM
So. California
axle Offline
axle  Offline
So. California
Shouldn't make a difference
Re: Wheel Vintiques issue [Re: axle] #1063555
08/26/11 11:50 PM
08/26/11 11:50 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Personally, I'd want what I ordered and paid for....
Re: Wheel Vintiques issue [Re: frank] #1063556
08/26/11 11:56 PM
08/26/11 11:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
How are you measuring them?
Re: Wheel Vintiques issue [Re: RobX4406] #1063557
08/26/11 11:57 PM
08/26/11 11:57 PM
IN
ahy Offline
ahy  Offline
IN
I'd mount one up (carefully wo/ scratches) and measure clearance. You will have to estimate tire bulge and diameter. If it is still a good fit, keep them. If the difference causes a problem, return them. Either way, I'd give them a call to make them aware of the problem.
Re: Wheel Vintiques issue [Re: ahy] #1063558
08/27/11 12:27 AM
08/27/11 12:27 AM
Cincinnati, Ohio
Cincinnati, Ohio
I'd carefully mount the steel wheel on your car and take a look before I would mount tires on one. This is what it says on there wheels.
Just painted mine today.
Re: Wheel Vintiques issue [Re: RobX4406] #1063559
08/27/11 12:27 AM
08/27/11 12:27 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
This..if you paid them a "little" less and said it was close enough to what they asked for..you can imagine thier response..
I order thousands of wheel components all the time..and I expect to get what I order, same would go for a single wheel.
Re: Wheel Vintiques issue [Re: OzHemi] #1063560
08/27/11 12:31 AM
08/27/11 12:31 AM
Cincinnati, Ohio
Cincinnati, Ohio
I agree no doubt. I wonder if the OP is measuring them right?
Re: Wheel Vintiques issue [Re: Challenger 1] #1063561
08/27/11 12:05 PM
08/27/11 12:05 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I put a straight edge accross the back lip and measure from the bottom of the straight edge to the wheel mount flange
Re: Wheel Vintiques issue [Re: frank] #1063562
08/27/11 12:23 PM
08/27/11 12:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
You must measure from inside the bead to the mounting flange, can't use a straight edge.
Re: Wheel Vintiques issue [Re: Challenger 1] #1063563
08/27/11 12:53 PM
08/27/11 12:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This is the correct way from back in the day but last night I checked about a dozen websites & they all showed the measurement taken from the rear lip....
As has been pointed out many times "I saw it on the internet so it must be true"
Think about it you measure rim width from tire bead 2 tire bead not rim edge 2 rim edge..... Back spacing is measured to the tire bead which would mean your rims are damn close to perfect....
Re: Wheel Vintiques issue [Re: 1_WILD_RT] #1063564
08/27/11 01:15 PM
08/27/11 01:15 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I remeasured and you are correct. The bead is .345 (average). When this is taken into account there is only a .03" difference. Thanks for educating me on the proper way to do this!
Re: Wheel Vintiques issue [Re: frank] #1063565
08/27/11 02:24 PM
08/27/11 02:24 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Wheel Vintiques issue [Re: Challenger 1] #1063566
08/27/11 10:55 PM
08/27/11 10:55 PM
Well I'll b damned, I had no idea that you didn't measure bs w a straightedge across the back esp as it pictured/explained like that everywhere
Re: Wheel Vintiques issue [Re: RapidRobert] #1063567
08/27/11 11:39 PM
08/27/11 11:39 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I have always measured back spacing across the very back edge of the wheel....as do all the people I know who build wheels
Re: Wheel Vintiques issue [Re: OzHemi] #1063568
08/27/11 11:42 PM
08/27/11 11:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
Well of course you use a straight edge across the rear bead to check BS, I worded it wrong above.
The thickness of the bead has to be accounted for in your measurments is all just like Frank stated above.
Re: Wheel Vintiques issue [Re: Challenger 1] #1063569
08/28/11 09:52 AM
08/28/11 09:52 AM
BDW Offline
BDW  Offline
I never understood this either, until I noticed they give offset and BS numbers for same rim, they always are about 1/2" difference. Finally figured out it was the method of measurement.
