Re: "A" Body Headers ?? What kind to use ?? Dart
[Re: 67GTMIKE]
#1063277
08/26/11 04:19 PM
08/26/11 04:19 PM
RapidRobert
TTI's would be what you are looking 4 but are pricey. Not sure if the collector is 3 or 3.5" on those
[Re: 67GTMIKE]
#1063278
08/26/11 04:31 PM
08/26/11 04:31 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Bob Mazzolini sells the Pro Parts style headers that work pretty well.
[Re: Chris2581]
#1063279
08/26/11 08:59 PM
08/26/11 08:59 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
The only cheap A-body headers are the Hedman 78030 for B-bodies. Very little if any massaging required. The problem is, they only fit with low-deck blocks... probably not worth trying with an RB. Hooker makes fenderwell headers which get in the way of everything (tires, ground...) Depending on how "built" your 440 is, would anyone recommend the Tri-Y's (Schumacher)?
