Getting Ready to "JAMB" my convertable, What all to do? #1063227
08/26/11 08:31 AM
08/26/11 08:31 AM
south central nebraska
GI Moparman Offline OP
Ive got my convertable body ready to paint the jambs and under hood and trunk areas. Just trying to figure out a good plan of attack. I wanna paint with fenders off. should i paint all the way to the outside sheet metal or stay back in aways. what im looking at is painting the windsheild frame, underhood, trunk right up to where the weather stripping glues for trunk seal so when trunk is on all under lid will be painted, door jambs to where with doors on all inside will be painted and leaving just exposed cowl area to be painted on front. Im using base clear if that matters. Any suggestions appriciated.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: GI Moparman] #1063228
08/26/11 10:42 AM
08/26/11 10:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO the whole car should be assembled, and stripped of all items not going to be painted body color, the only componets that should be jambed off the car, prior to painting, are the hood and trunklid, the entire body should be assembled and panel aligned, shoot the body/engine compartment/door jambs/trunk jamb at the same time, painted mirrors and such can be painted off the car at this time, depending on the color, your skill level, humidty, etc, etc, batch painting major panels off the car can result in shade/texture differences, best to paint the car as whole as you can, there are exceptions for each car/componets,...plus installing pre painted fenders/doors/etc always leads to that "uh-Oh!" boo boo
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: DAYCLONA] #1063229
08/26/11 12:11 PM
08/26/11 12:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's my take too
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: Morty426] #1063230
08/26/11 12:26 PM
08/26/11 12:26 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's my plan... Shoot door jambs, trunk, engine bay, inside of doors, underside of hood, etc. Then hang all panels, mask the jambs from overspray, and shoot entire outside of car at once
**Photobucket sucks**
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: 70Cuda383] #1063231
08/26/11 12:38 PM
08/26/11 12:38 PM
My plans are like 70cuda383 is talking bout. I will then assemble the car and align then paint entire car as one with the hood off and door jambs masked off. I understand the color differance and probs with painting panels on diff days and such. WHat i was wondering is where is the best place to make the tape lines on door jambs, underhood and is it better to paint with trunk lid off also. I guess that would eliminate tape lines in trunk weather stripping area. Thanks and hope that cleared up my intentions.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: GI Moparman] #1063232
08/26/11 01:16 PM
08/26/11 01:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You avoid "tape lines" by "back taping", that involves rolling the tape over on itself, so that you leave a soft edge, that you blend into later, avoid hard taping (leaving an edge), you either back tape, or you let the tape overlap the edge of the panel being jambed, later on, lets say in a door jamb they may have been jambed prior to painting the entire car, you can use apperture tape, it's like a foam cord, with a strip of semi tack adhesive on one side, you install it on the jambed paint edge, exposing just a thin line of color on your back taped painted edge, then close the door/panel/trunk lid/etc/etc/etc, it leaves the panel gap blocked off from overspray, yet allows (depending on the depth you set it at) the paint to wick in and blend softly with the "jambed" jamb, leaving you with a professional blending of the main body paint and the jamb paint, apperture tape is only used on pre jambed areas, or areas you don't want paint entering, but yet want a soft transition line of color/spray
Mike
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: 70Cuda383] #1063233
08/26/11 03:26 PM
08/26/11 03:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can't do it like that, got to do it like dayclona discribed.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: Challenger 1] #1063234
08/26/11 08:58 PM
08/26/11 08:58 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
I like to do all of them this way. No tape lines or dry jambs.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: DAYCLONA] #1063235
08/29/11 01:23 AM
08/29/11 01:23 AM
Oakley CA
69charger440_6pa Offline
Oakley CA
How do you recommend doing this all at the same time? Are you opening and closing the doors as you go?
The last car i did I shot in pieces and reassembled. It turned out great however I would much rather shoot it all together but I want to avoid tape lines.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: 69charger440_6pa] #1063236
08/29/11 01:29 AM
08/29/11 01:29 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
And, if a car is painted without fenders installed, how does one get the fender bolts on and painted such that it appears as if painted assembled? I assume that would require masking off and painting only the fender attachment areas, but, then, tape lines?
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: lahatte] #1063237
09/03/11 08:50 PM
09/03/11 08:50 PM
It sure dont work to paint then install the bolts! I did n they look like s"#%! Gonna pull them back out strip n tape off to paint on the car.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: BarrsRestoration] #1063238
09/04/11 01:21 AM
09/04/11 01:21 AM
Jacksonville Florida
elitecustombody Offline
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: BarrsRestoration] #1063239
09/04/11 01:26 AM
09/04/11 01:26 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Must be snowing in HeII, I actually agree with Dayclona!
You don't have to worry about tape lines either because there's usually nothing to tape off! Also, don't forget the body caulking between the fenders and inner fenders, etc. that got painted over as well.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: ScottSmith_Harms] #1063240
09/04/11 07:41 PM
09/04/11 07:41 PM
N
newem Offline
newem  Offline
N
How did the factory paint it all?
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: newem] #1063241
09/04/11 09:40 PM
09/04/11 09:40 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Short answer....not worth a sheite!
Real answer, painted all together and did mostly a poor job in engine compartments,trunks, and door jambs. Outside was decent for the era in which they were built.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: newem] #1063242
09/04/11 10:03 PM
09/04/11 10:03 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
From what I've seen from the cars I've disassembled, it appears that the body was assembled except for the hood, and possibly the trunk. But I believe most had the truck installed when the car was painted because the mount point didn't get painted, and the bolts were painted.
Hood bolts on a 1970 cuda I had were plated, not painted. On this 1972, however, it appears as if the hood was painted on the car...
http://www.creative-machining.com/claylahatte/auto/1971cudaconv_java/#IMG_1717.jpg
The trunk bolts...
http://www.creative-machining.com/claylahatte/auto/1971cudaconv_java/#IMG_1692.jpg
Oh, I also believe the front and rear valance panels were painted off the car.
Re: Getting Ready to "JAMB" my convertable, What all to do? [Re: lahatte] #1063243
09/04/11 11:00 PM
09/04/11 11:00 PM
MO
cdp Offline
cdp  Offline
MO
A little humor and some "back-taping" education.
http://www.youtube.com/watch?v=CHwjn0EpuTE
