Re: Getting Ready to "JAMB" my convertable, What all to do?
[Re: GI Moparman]
#1063228
08/26/11 10:42 AM
08/26/11 10:42 AM
Posts: 18,157 Mass
DAYCLONA
Mass
IMHO the whole car should be assembled, and stripped of all items not going to be painted body color, the only componets that should be jambed off the car, prior to painting, are the hood and trunklid, the entire body should be assembled and panel aligned, shoot the body/engine compartment/door jambs/trunk jamb at the same time, painted mirrors and such can be painted off the car at this time, depending on the color, your skill level, humidty, etc, etc, batch painting major panels off the car can result in shade/texture differences, best to paint the car as whole as you can, there are exceptions for each car/componets,...plus installing pre painted fenders/doors/etc always leads to that "uh-Oh!" boo boo
[Re: DAYCLONA]
#1063229
08/26/11 12:11 PM
08/26/11 12:11 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
That's my take too
[Re: Morty426]
#1063230
08/26/11 12:26 PM
08/26/11 12:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
That's my plan... Shoot door jambs, trunk, engine bay, inside of doors, underside of hood, etc. Then hang all panels, mask the jambs from overspray, and shoot entire outside of car at once
**Photobucket sucks**
[Re: GI Moparman]
#1063232
08/26/11 01:16 PM
08/26/11 01:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
My plans are like 70cuda383 is talking bout. I will then assemble the car and align then paint entire car as one with the hood off and door jambs masked off. I understand the color differance and probs with painting panels on diff days and such. WHat i was wondering is where is the best place to make the tape lines on door jambs, underhood and is it better to paint with trunk lid off also. I guess that would eliminate tape lines in trunk weather stripping area. Thanks and hope that cleared up my intentions.
You avoid "tape lines" by "back taping", that involves rolling the tape over on itself, so that you leave a soft edge, that you blend into later, avoid hard taping (leaving an edge), you either back tape, or you let the tape overlap the edge of the panel being jambed, later on, lets say in a door jamb they may have been jambed prior to painting the entire car, you can use apperture tape, it's like a foam cord, with a strip of semi tack adhesive on one side, you install it on the jambed paint edge, exposing just a thin line of color on your back taped painted edge, then close the door/panel/trunk lid/etc/etc/etc, it leaves the panel gap blocked off from overspray, yet allows (depending on the depth you set it at) the paint to wick in and blend softly with the "jambed" jamb, leaving you with a professional blending of the main body paint and the jamb paint, apperture tape is only used on pre jambed areas, or areas you don't want paint entering, but yet want a soft transition line of color/spray
Mike
[Re: DAYCLONA]
#1063235
08/29/11 01:23 AM
08/29/11 01:23 AM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
How do you recommend doing this all at the same time? Are you opening and closing the doors as you go? The last car i did I shot in pieces and reassembled. It turned out great however I would much rather shoot it all together but I want to avoid tape lines.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
[Re: BarrsRestoration]
#1063239
09/04/11 01:26 AM
09/04/11 01:26 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Must be snowing in HeII, I actually agree with Dayclona!
You don't have to worry about tape lines either because there's usually nothing to tape off! Also, don't forget the body caulking between the fenders and inner fenders, etc. that got painted over as well.
[Re: newem]
#1063241
09/04/11 09:40 PM
09/04/11 09:40 PM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
How did the factory paint it all?
Short answer....not worth a sheite!
Real answer, painted all together and did mostly a poor job in engine compartments,trunks, and door jambs. Outside was decent for the era in which they were built.
