1969 Dart front brakes #1062906
08/25/11 05:04 PM
08/25/11 05:04 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
How can I tell if my Dart has 9" or 10" front brakes. I dont have access to measure it right now. My build sheet has 11 under 'front brake'.
Re: 1969 Dart front brakes [Re: Nirvana] #1062907
08/25/11 05:13 PM
08/25/11 05:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
B11 is heavy duty 10" drum - auto adjust .
Re: 1969 Dart front brakes [Re: JohnRR] #1062908
08/25/11 05:21 PM
08/25/11 05:21 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Thank you.Should it show B11 on my sheet? It only shows 11 under the "Front Brake" box.
Re: 1969 Dart front brakes [Re: Nirvana] #1062909
08/25/11 06:30 PM
08/25/11 06:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is in the SECTION labeled B correct ?
Re: 1969 Dart front brakes [Re: Nirvana] #1062910
08/25/11 07:07 PM
08/25/11 07:07 PM
I think the spindle shank drops straight down on 10" and kicks out at an angle on 9" ers. I have a 10" spindle being returned in several hours so I will check back later w what I see EDIT I may have that backwards, I'll know in a bit
Re: 1969 Dart front brakes [Re: JohnRR] #1062911
08/25/11 08:52 PM
08/25/11 08:52 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
No,I dont have anything in the B section. This is in the top part of the sheet under "Front Brake"
Re: 1969 Dart front brakes [Re: Nirvana] #1062912
08/26/11 10:53 PM
08/26/11 10:53 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
I swapped my 73 Dart drums to stock disks from a 75 Dart years ago; no issues!
Re: 1969 Dart front brakes [Re: Nirvana] #1062913
08/27/11 02:34 AM
08/27/11 02:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then disregard my reply , can't say ...
Re: 1969 Dart front brakes [Re: Nirvana] #1062914
08/28/11 09:24 PM
08/28/11 09:24 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If the car is unmolested, factory /6 cars got 9" brakes, while V8's got 10" (not sure about 273 V8).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 1969 Dart front brakes [Re: Nirvana] #1062915
08/28/11 09:56 PM
08/28/11 09:56 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I think the 11 is the last 2 digits of the brake assembly used in production with no way to cross reference. If there are no numbers in the B/brake section then no optional brakes were ordered. Attached is the brake size info from the dealer data book.
Re: 1969 Dart front brakes [Re: moparfan53] #1062916
08/28/11 11:24 PM
08/28/11 11:24 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Ok thanks you guys. I am going to be ordering the scarebird brake brackets and they have one for 9" or 10" brakes,just wanted to clear it up.
Jared
Re: 1969 Dart front brakes [Re: Nirvana] #1062917
08/28/11 11:38 PM
08/28/11 11:38 PM
The guy hasn't brought the 10" spindle back so I could check it like I wanted 2 for you but you've got it
Re: 1969 Dart front brakes [Re: Nirvana] #1062918
08/29/11 03:12 AM
08/29/11 03:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Jared
I believe you could over at HD brake package and get 10" on a /6 car.
Always best to go measure and check the car.
Re: 1969 Dart front brakes [Re: autoxcuda] #1062919
08/29/11 03:35 AM
08/29/11 03:35 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
My 273 dart had 9in drums in the front.
Ditched them in favor of the KH disc setup
