Help with A/F Ratio Numbers #1062760
08/25/11 11:05 AM
08/25/11 11:05 AM
Mass.
charger_dart Offline OP
Mass.
I hooked up a NGK Air Fuel ratio guage to my 500 wedge motor with a Holley 80531 850 carb (vacuum secondary) The numbers I got were:
Idle - 13.5
Cruise - 12.5
Light throttle - 13.5
Decelerate - 11.5
WOT - 13.5 dropping to 12.5 as the secondaries open
Do these look like good numbers? This carb replaced an Eddy 800 and seems to run pretty good right out of the box.
Thanks for all comments
68 Charger R/T 68 Dart G/T Convert 11 Challenger SRT
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062761
08/25/11 12:01 PM
08/25/11 12:01 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Idle - 13.5
Cruise - 12.5
Decelerate - 11.5
The cruise is too rich. That will hurt mileage. Idle should be about 14 to 14.5 (depends on what the motor wants) and your cruise should be about the same as idle, maybe a tad richer.
The WOT is fine.
The decel is showing rich only because there's excess fuel being burned off. On a long decel, given time to burn off the fuel, the AF ratio should go as lean as idle.
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062762
08/25/11 12:27 PM
08/25/11 12:27 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I started out with my in D idle around 14.2-14.4 but my rpms would jump around too much so now I keep it around the 13.6-13.8 range. My N idle is usually a tad leaner 13.8-14.0 or so.
My cruising range is 14.2 to 15.5. Anything close to 16 and I get worried and retune.
My light throttle feels more responsive in the 13.6-13.8 range. I have tried as lean as 14.4 but it just felt a little soft.
My decel gets down to 13.5 or so.
Once you lean out your cruise then the decel should lean out too.
Re: Help with A/F Ratio Numbers [Re: YO7_A66] #1062763
08/25/11 01:05 PM
08/25/11 01:05 PM
Mass.
Mass.
Thanks for the comments. That's kind of what I thought - So maybe a jet change on the primary side will get me into a better condition?
Currently I have 78's on the primary side and 82's on the secondary side. What jet size should i try to go to?
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062764
08/25/11 01:17 PM
08/25/11 01:17 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
You should see an immediate change on the A/F meter if you go at least 2 jet sizes and if you test with the same outside temps. But if the meter stays with the same reading, then the transition circuit would need to be tuned instead of the primary jetting.
Re: Help with A/F Ratio Numbers [Re: YO7_A66] #1062765
08/25/11 04:12 PM
08/25/11 04:12 PM
Mass.
Mass.
Ok, I will put 76's on the primary side and see what readings I get. Thanks!!
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062766
08/25/11 04:38 PM
08/25/11 04:38 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Keep lowering your primary jetting until you get the cruising A/F that you want. Then you will have to go back and recheck your secondary jetting for your WOT A/F since you are removing jet out of the primary side of the carb.
Re: Help with A/F Ratio Numbers [Re: YO7_A66] #1062767
08/26/11 08:18 AM
08/26/11 08:18 AM
Mass.
Mass.
I don't believe this! I pulled my NEW carb apart for the first time to change the jets and found the primary float has been crushed. It had barely 1/8" of movement!!
Where is the quality control at Holley???
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062768
08/26/11 01:25 PM
08/26/11 01:25 PM
I have a Innovate dual wide ban on my car, I like to see 14.5 or leaner at idle and close to that at part throttle, 12.8 to 13.3 at WOT makes my car run the fastest at the track It is a pump gas car that runs in the low tens at 133. MPH so far As far as the float have you had the car real hot since putting that carb. on also did you buy it(the carb.) new? I have seen several floats ike that in used carbs. I don't think Holley has used brass floats in there new carbs. in a lot of years due to the fuel mixes that are used today, IE alholol
Re: Help with A/F Ratio Numbers [Re: Cab_Burge] #1062769
08/29/11 04:26 PM
08/29/11 04:26 PM
Mass.
Mass.
Thanks for posting what numbers work well for you. I also run pump gas in my car.
The carb was purchased new from amazon.com and I can't think of what would of caused it to crush like that. Its as if it was sent to the bottom of the ocean or something. The replacement float came air freight and was brass also - in perfect condition!
Now I just have to see what effect the jet change and float fix has had. Will post pack later.
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062770
08/29/11 08:04 PM
08/29/11 08:04 PM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
Sorry if this is a bit of a hijack, but I'm interested in messing around with a wideband. I would hope to be taking it car to car, but cars I want to start out with already have narrow band sensors. Will I still be able to get a usable signal to computer? How's it work?
Re: Help with A/F Ratio Numbers [Re: FK5] #1062771
08/29/11 08:19 PM
08/29/11 08:19 PM
dogdays Offline
dogdays  Offline
You're at close to sea level. I bet you don't need to change jets at all. Just change the float and go for a drive. Those new Holleys are pretty close out of the box.
My Holley was running way rich. I found the secondary float stuck open, I was getting fuel injection (well, kind of) out of the secondary side. I cleaned the needle and seat, reset the float and the condition went away.
R.
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062772
08/31/11 04:13 AM
08/31/11 04:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Does holley have a quality control department?
My Truck Avenger did not run right either.
When I pulled it apart there were two brass slugs in the jet wells behind the jets
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062773
08/31/11 08:28 PM
08/31/11 08:28 PM
AndyF Offline
AndyF  Offline
The problem you'll have is doing anything about those numbers. To lean out the cruise you'll most likely need to reduce main jets by a size or two, but when you do that the WOT will be too lean. To fix the WOT you'll need to open up the PVCR restriction. On the Ultra carbs you can change jets in the metering block but I don't think a 80531 will have jets in the PVCR. You'll probably have to do a little drill work to get that carb dialed in just right.
Of course, you might get lucky. Start by leaning out the idle and see if that fixes the cruise also. If it does then you might be fine at WOT.
Re: Help with A/F Ratio Numbers [Re: AndyF] #1062774
08/31/11 08:52 PM
08/31/11 08:52 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You likely won't get it refined by changing main jets, especially if your cruise rpm is in the 2500 or less range.
A side note: The HP series holleys are horribly rich pigs on cruise and main jet change don't clean them up.
Re: Help with A/F Ratio Numbers [Re: RobX4406] #1062775
08/31/11 10:30 PM
08/31/11 10:30 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
If leaning out the main jets does not lean the A/F number, then the IFR's need to be smaller. The IFR's control the transition circuit which is activated after the idle circuit and before the main circuit.
Re: Help with A/F Ratio Numbers [Re: RobX4406] #1062776
08/31/11 10:41 PM
08/31/11 10:41 PM
AndyF Offline
AndyF  Offline
It is quite possible that the main jets aren't doing much at 2500 rpm. Every combo is different but even a 500 inch motor might not be pulling much fuel thru the mains at cruise. If that is the case then the idle circuit is the one to pay attention to.
Once again, those cast metering blocks are going to be a hurdle. The Ultra Holley carbs have idle jets in the metering blocks which can be quickly changed. The other Holley carbs have pressed in restrictors which are not that easy to modify.
Re: Help with A/F Ratio Numbers [Re: YO7_A66] #1062777
08/31/11 11:09 PM
08/31/11 11:09 PM
RobX4406 Offline
RobX4406  Offline
Yep, and the blocks aren't that tough to alter to make them adjustable. Need the tools and brass and you're off and running.
Re: Help with A/F Ratio Numbers [Re: RobX4406] #1062778
09/01/11 11:06 AM
09/01/11 11:06 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
For WOT tuning I like to have a dyno. The A/F ratio numbers are nice to have, but the dyno tells the story. Tuning for max power may want more fuel or it may want less. But I like to tune for it and that way I know which way I can safely go (richer or leaner) to tune for fuel economy and not hurt the motor when I do have my foot in it. It's often a compromise with a carb.
Re: Help with A/F Ratio Numbers [Re: charger_dart] #1062779
09/01/11 06:26 PM
09/01/11 06:26 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Guys, I have been playing for years with my QF-750 and my LM2 and was wondering how can I make the part throtle richer while making the idle leaner?
I Have changed my IFR down to 31's, my idle screws are still only about 3/4 of a turn to have 14 at idle but my part throtle is too lean...
Also, my primary accelerator pump does not perform as well as the seconday... If I tap on the plunger with my finger I have an immediate spray on the secondary pump but not on the primary. I have changed all the parts for new parts with no improvement (diaphragm, valve, needle valve etc...) and there is no gap between the plunger and the arm...
