Help with A/F Ratio Numbers
#1062760
08/25/11 11:05 AM
08/25/11 11:05 AM
Posts: 38 Mass.
charger_dart
Mass.
I hooked up a NGK Air Fuel ratio guage to my 500 wedge motor with a Holley 80531 850 carb (vacuum secondary) The numbers I got were: Idle - 13.5 Cruise - 12.5 Light throttle - 13.5 Decelerate - 11.5 WOT - 13.5 dropping to 12.5 as the secondaries open Do these look like good numbers? This carb replaced an Eddy 800 and seems to run pretty good right out of the box. Thanks for all comments
68 Charger R/T
68 Dart G/T Convert
11 Challenger SRT
Re: Help with A/F Ratio Numbers
[Re: charger_dart]
#1062761
08/25/11 12:01 PM
08/25/11 12:01 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
The cruise is too rich. That will hurt mileage. Idle should be about 14 to 14.5 (depends on what the motor wants) and your cruise should be about the same as idle, maybe a tad richer.
The WOT is fine.
The decel is showing rich only because there's excess fuel being burned off. On a long decel, given time to burn off the fuel, the AF ratio should go as lean as idle.
[Re: charger_dart]
#1062762
08/25/11 12:27 PM
08/25/11 12:27 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I started out with my in D idle around 14.2-14.4 but my rpms would jump around too much so now I keep it around the 13.6-13.8 range. My N idle is usually a tad leaner 13.8-14.0 or so. My cruising range is 14.2 to 15.5. Anything close to 16 and I get worried and retune. My light throttle feels more responsive in the 13.6-13.8 range. I have tried as lean as 14.4 but it just felt a little soft. My decel gets down to 13.5 or so.
Once you lean out your cruise then the decel should lean out too.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1062763
08/25/11 01:05 PM
08/25/11 01:05 PM
Posts: 38 Mass.
charger_dart
Mass.
Thanks for the comments. That's kind of what I thought - So maybe a jet change on the primary side will get me into a better condition?
Currently I have 78's on the primary side and 82's on the secondary side. What jet size should i try to go to?
68 Charger R/T
68 Dart G/T Convert
11 Challenger SRT
[Re: charger_dart]
#1062764
08/25/11 01:17 PM
08/25/11 01:17 PM
YO7_A66
Indiana
You should see an immediate change on the A/F meter if you go at least 2 jet sizes and if you test with the same outside temps. But if the meter stays with the same reading, then the transition circuit would need to be tuned instead of the primary jetting.
[Re: charger_dart]
#1062766
08/25/11 04:38 PM
08/25/11 04:38 PM
YO7_A66
Indiana
Keep lowering your primary jetting until you get the cruising A/F that you want. Then you will have to go back and recheck your secondary jetting for your WOT A/F since you are removing jet out of the primary side of the carb.
[Re: charger_dart]
#1062772
08/31/11 04:13 AM
08/31/11 04:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Does holley have a quality control department? My Truck Avenger did not run right either. When I pulled it apart there were two brass slugs in the jet wells behind the jets
[Re: charger_dart]
#1062773
08/31/11 08:28 PM
08/31/11 08:28 PM
Posts: 31,049 Oregon
AndyF
The problem you'll have is doing anything about those numbers. To lean out the cruise you'll most likely need to reduce main jets by a size or two, but when you do that the WOT will be too lean. To fix the WOT you'll need to open up the PVCR restriction. On the Ultra carbs you can change jets in the metering block but I don't think a 80531 will have jets in the PVCR. You'll probably have to do a little drill work to get that carb dialed in just right.
Of course, you might get lucky. Start by leaning out the idle and see if that fixes the cruise also. If it does then you might be fine at WOT.
[Re: RobX4406]
#1062775
08/31/11 10:30 PM
08/31/11 10:30 PM
YO7_A66
Indiana
If leaning out the main jets does not lean the A/F number, then the IFR's need to be smaller. The IFR's control the transition circuit which is activated after the idle circuit and before the main circuit.
[Re: YO7_A66]
#1062777
08/31/11 11:09 PM
08/31/11 11:09 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Yep, and the blocks aren't that tough to alter to make them adjustable. Need the tools and brass and you're off and running.
