Page 1 of 3 1 2 3
Track report ! #1062663
08/25/11 01:35 AM
08/25/11 01:35 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Yes I drove to the track tonight and put 2 passes on my 63. I had some problems and found out it was way lean.
First pass it just would not rev good and felt real flat......11.27 @ 113 !
Yuk but my brother was watching and he said it looked good as it pulled about 6 inches under the front wheels but I said it felt real bad. I had just stuck the 850 DP on that was on my old 440 and I knew it needed more carb but I used what I had. Well we pulled the 80 primary jets and put 86's in. Car started fine and idled fine. Next and final pass for the night.........11.04 @ 121.42. Ok we made a drastic jet change to find out we are going in the right direction. We were going to pull the secondary bowl but I decided to call it a night as my back was hurting alot and my left knee was giving me alot of pain and I was not up to any more work. So I called it a night telling myself that 11.04 @ 121 is not to bad for the second ever pass on my pump gas full exh 3700 lb street car that I drove the 90 mile round trip. I will pull the carb and work it over this week. I wish I had a Dominator or a nice 950 to try but I will use what I have. I honestly think it has easy 10.80's or better and I hope to find out soon. I know I could have jetted the secondary side and came home with a 10.9 something pass but I was just not up to it. I had fun and hope to get back to the track in a month or so. Ron
Re: Track report ! [Re: 383man] #1062664
08/25/11 01:40 AM
08/25/11 01:40 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Geez, 11.04 @ 121 first time out, 3700#, DRIVEN there and back...
GREAT first couple of laps! Congrats!!!!
Sorry about your pains, but you're right..it's alot less fun when you're hurting, is it?
This fall it will go in the 10's EASY with the 850, but yea it probably needs more air and fuel.
Re: Track report ! [Re: 383man] #1062665
08/25/11 01:45 AM
08/25/11 01:45 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I am impressed Ron, that thing is running nice and strong! And the fact that it is a pump gas engine that can be driven and knock of 10 second passes is saying something in my book! I myself would like to see my car run an easy 11.50 or so with its current gear and driveline setup and I would be a happy man! Your are definitly running old school iron and showing the guys with modern muscle that the older cars can still perform and show them some taillights.
Re: Track report ! [Re: cudadoug] #1062666
08/25/11 01:45 AM
08/25/11 01:45 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
cool !
glad it went well
maybe you need to step up to a proform 950 or Hp1000,bit bigger than a Holley 850
they are cheap enough on your end of the world
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Track report ! [Re: tex013] #1062667
08/25/11 06:55 AM
08/25/11 06:55 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Congrats Ron
I thought 10.90's first time out, so i wasn't to far off. I agree with Tex a 950 or bigger carb would help it, maybe play with timing and carb jetting.
At least you had no major issues.
What were your 1/8 mile times and 60ft, also weather.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Track report ! [Re: deaks] #1062668
08/25/11 07:07 AM
08/25/11 07:07 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
hows that 493 torque feel ?
pulls hard dont she ......
cool that you drove it that far and back
Re: Track report ! [Re: 493_DART] #1062669
08/25/11 07:25 AM
08/25/11 07:25 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
That car is definitely smelling of the 10's!! I bet it felt good to return to the track after such a long absence. Has your job situation improved? Keep us posted.
Re: Track report ! [Re: Mr. T] #1062670
08/25/11 09:42 AM
08/25/11 09:42 AM
tboomer Offline
tboomer  Offline
Good first outing,Ron!! I would like to see a Dominator on your 493...Then...Hang on!!
Re: Track report ! [Re: 383man] #1062671
08/25/11 09:51 AM
08/25/11 09:51 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good first outing for sure. You need a 1050 dominator in my opinion and the 2-circuit works fine on the street when dialed in. Save yourself lots of pain and wear and tear on your motor and install a wide band..............you`ll get that 10 sec. pass first time out after tweeking it on the street and not hurt your motor.
Re: Track report ! [Re: Thumperdart] #1062672
08/25/11 10:01 AM
08/25/11 10:01 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cool good first hits!
Re: Track report ! [Re: Dodgem] #1062673
08/25/11 10:35 AM
08/25/11 10:35 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
CONGRATS RON! I agree with Thumper. A 1050 will do that motor right! I agree 10.80's in your future. Gotta feed the beast!
Re: Track report ! [Re: Thumperdart] #1062674
08/25/11 10:56 AM
08/25/11 10:56 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Congrat's on the first outing Ron, Good #'s
X2 on the wideband, I installed one on my car this year and it's been real helpful.
Gary.
Re: Track report ! [Re: 383man] #1062675
08/25/11 12:07 PM
08/25/11 12:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good deal Ron, been looking forward to that
6" wheelies are pretty good for a street car
Rich H.
Esse Quam Videri
Re: Track report ! [Re: 383man] #1062676
08/25/11 02:59 PM
08/25/11 02:59 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very nice results and I hope you feel better soon.
Re: Track report ! [Re: HardcoreB] #1062677
08/25/11 03:17 PM
08/25/11 03:17 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Ron - If you want to try out an SV-1 let me know...
Congrats on getting out and running the beast!
Re: Track report ! [Re: DJVCuda] #1062678
08/25/11 03:52 PM
08/25/11 03:52 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Sounds like a good first outing. Little carb tuning with what to got will get you that 10 in hot weather.
Getting old just means you were smarter than some and luckier than others.
Re: Track report ! [Re: dannysbee] #1062679
08/25/11 06:35 PM
08/25/11 06:35 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
AWESOME!!!!! Looks like Jr NEEDS to step it up now!!!!!
Re: Track report ! [Re: 383man] #1062680
08/25/11 06:38 PM
08/25/11 06:38 PM
AndyF Offline
AndyF  Offline
Most 950 carbs are smaller than an 850 DP so don't go backwards.
The only "true" 950 that I'm aware of is the new 80805 Holley. Otherwise you might as well stick with the 850 and just get it dialed in correctly.
Re: Track report ! [Re: AndyF] #1062681
08/25/11 06:57 PM
08/25/11 06:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice job! Congrats on a good first outing with the new bullet!
Re: Track report ! [Re: Bigcube] #1062682
08/25/11 07:10 PM
08/25/11 07:10 PM
New York, USA
Chargerfan68 Offline
New York, USA
Congratulations Ron!! Great job with the new motor and very nice times so far. 10's are in the bag. Was that Cecil that you ran at?
Best of luck with you new motor.
Greg.
Page 1 of 3 1 2 3
