ARP Rocker Shaft Stud Kit #1062564
08/24/11 10:07 PM
08/24/11 10:07 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Does anyone have a part # for the stud kit
for rocker shafts, I need to replace my bolts,
and would like to go with studs, tried looking
around and couldn't come up with anything from ARP.
Re: ARP Rocker Shaft Stud Kit [Re: 65racer] #1062565
08/24/11 10:20 PM
08/24/11 10:20 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
There is no kit # per say.
I have the studs here seperately with nuts etc.
What rockers are you using?
RIP Monte Smith
Re: ARP Rocker Shaft Stud Kit [Re: 65racer] #1062566
08/24/11 10:33 PM
08/24/11 10:33 PM
AndyF Offline
AndyF  Offline
I don't think ARP ever set it up as a part numbered kit but they have the parts if you call them.
Re: ARP Rocker Shaft Stud Kit [Re: 65racer] #1062567
08/25/11 03:21 AM
08/25/11 03:21 AM
Which set of cylinder heads, the Eddy RPM and stock are different than the Indy heads As already said the studs have to be ordered individually by the length needed
Re: ARP Rocker Shaft Stud Kit [Re: 65racer] #1062568
08/25/11 03:33 AM
08/25/11 03:33 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Magnum HP may be able to help you! Need to query this website for website/contact info! I got an ARP set from him but they were for indy heads! Got a nice shirt out of the deal too! good luck.
Re: ARP Rocker Shaft Stud Kit [Re: Plumcrazyracing] #1062569
08/25/11 09:44 AM
08/25/11 09:44 AM
tboomer Offline
tboomer  Offline
Dave...Check with Hughes...They have kits available!
Re: ARP Rocker Shaft Stud Kit [Re: tboomer] #1062570
08/25/11 11:16 PM
08/25/11 11:16 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Davey, I bought a Huges Engines rocker shaft stud kit a few years ago but they didn't work well for me. I think they're still here SOMEWHERE if you want to try them. What I didn't like about studs, when I screwed them all the way into the stands, they weren't long enough to suit me. If I didn't screw them all the way down, when I put the nuts on, they screwed down anyway . If you bought ARP's the correct lenght, may not have that problem If you want, I'll look tomorrow for the Hughes studs.
Brian Dunnigan
Re: ARP Rocker Shaft Stud Kit [Re: CompWedgeEngines] #1062571
08/25/11 11:30 PM
08/25/11 11:30 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
How about for Victor style heads with Harland Sharp rockers?
