Re: ARP Rocker Shaft Stud Kit
[Re: 65racer]
#1062565
08/24/11 10:20 PM
08/24/11 10:20 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
There is no kit # per say.
I have the studs here seperately with nuts etc.
What rockers are you using?
RIP Monte Smith
[Re: tboomer]
#1062570
08/25/11 11:16 PM
08/25/11 11:16 PM
Posts: 2,037 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Davey, I bought a Huges Engines rocker shaft stud kit a few years ago but they didn't work well for me. I think they're still here SOMEWHERE if you want to try them. What I didn't like about studs, when I screwed them all the way into the stands, they weren't long enough to suit me. If I didn't screw them all the way down, when I put the nuts on, they screwed down anyway . If you bought ARP's the correct lenght, may not have that problem If you want, I'll look tomorrow for the Hughes studs. Brian Dunnigan
[Re: CompWedgeEngines]
#1062571
08/25/11 11:30 PM
08/25/11 11:30 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
How about for Victor style heads with Harland Sharp rockers?
