E-Body Emergency Brake Cable Clip Source #1062151
08/24/11 02:58 PM
08/24/11 02:58 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I'm looking for this clip. It is located on the driver's side on the rocker (pinch weld) just behind front fender.
Does anyone know who may carry this?
I'm waiting to hear back from Tom at R/T Specialties. Fine Lines doesn't have it.
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062152
08/24/11 02:58 PM
08/24/11 02:58 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Pic 2
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062153
08/24/11 03:22 PM
08/24/11 03:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What years used that clip?
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062154
08/24/11 04:36 PM
08/24/11 04:36 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I have two x 71 Challengers. One has it, one doesn't. The one that doesn't looks like this. Sorry, I don't have a definative answer on the years. The car that has the clip was restored at one point.
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062155
08/24/11 05:27 PM
08/24/11 05:27 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's what mine looks like too. If a clip is avaiable, I might add one.
Re: E-Body Emergency Brake Cable Clip Source [Re: burdar] #1062156
08/24/11 06:15 PM
08/24/11 06:15 PM
MD
floyd Offline OP
floyd  Offline OP
MD
A friend just looked at this post and told me it's a "speedo cable clip".
Google is your friend if you know the name of the part you're looking for.
http://www.rtspecialties.net/proddetail.asp?prod=1000092
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062157
08/24/11 07:31 PM
08/24/11 07:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: E-Body Emergency Brake Cable Clip Source [Re: gtx6970] #1062158
08/24/11 07:42 PM
08/24/11 07:42 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Is that clip also used for the speedo cable on the drivers side frame rail below the brake master cylinder? TIA
Ray
Re: E-Body Emergency Brake Cable Clip Source [Re: rayztoy] #1062159
08/24/11 07:45 PM
08/24/11 07:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ray
This is a B-body but my challenger had one is this exact same location holding the speedo cable
Re: E-Body Emergency Brake Cable Clip Source [Re: gtx6970] #1062160
08/24/11 07:59 PM
08/24/11 07:59 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Bill,
Do you know where to source that clip (pn 0500)?
Ray
Re: E-Body Emergency Brake Cable Clip Source [Re: rayztoy] #1062161
08/24/11 08:06 PM
08/24/11 08:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ray,
Jamie at Megaparts has the clip ( link posted above )
pn0500 is the clip to the bottom right of the above picture
Re: E-Body Emergency Brake Cable Clip Source [Re: rayztoy] #1062162
08/24/11 08:58 PM
08/24/11 08:58 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Bill,
I'm sorry, I thought the circled clip was the 0500. Do you know where to source the circled clip?
Ray
Re: E-Body Emergency Brake Cable Clip Source [Re: rayztoy] #1062163
08/24/11 09:26 PM
08/24/11 09:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ray
http://www.megapartsusa.com/proddetail.asp?prod=MP%2DSCC100S
Re: E-Body Emergency Brake Cable Clip Source [Re: gtx6970] #1062164
08/24/11 10:37 PM
08/24/11 10:37 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Thank you Bill!
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062165
08/27/11 12:50 PM
08/27/11 12:50 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Sorry Bruce, but the e-brake cable on your black Challenger is routed incorrectly. The clip your lookin for is for the speedo cable only. The e-brake is routed through the hole behind the fender and on the inside of the framerail. The 71 Challenger does NOT use that speedo cable clip for the e-brake.
Re: E-Body Emergency Brake Cable Clip Source [Re: THESHAKERPROJECT] #1062166
08/27/11 01:38 PM
08/27/11 01:38 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Mike - Can you post a pic? Thanks
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062167
08/27/11 03:10 PM
08/27/11 03:10 PM
NORTHERN VA
NORTHERN VA
too much stuff in the garage due to the storm and cant get around the car to take a pic but if you look inside the fender you will see the hole the cable routes through and it held in the next smaller hole with a retainer same as the other end. Both of my 71s were this way.
Re: E-Body Emergency Brake Cable Clip Source [Re: floyd] #1062168
08/28/11 05:02 PM
08/28/11 05:02 PM
Chicagoland
cudastruction Offline
Chicagoland
Here is a pic that shows how the e-brake cable is routed up front (I don't have an shot from under)...
Re: E-Body Emergency Brake Cable Clip Source [Re: cudastruction] #1062169
08/29/11 10:29 AM
08/29/11 10:29 AM
MD
floyd Offline OP
floyd  Offline OP
MD
thanks!
