Re: E-Body Emergency Brake Cable Clip Source
[Re: floyd]
#1062152
08/24/11 02:58 PM
08/24/11 02:58 PM
Posts: 4,114 MD
floyd
MD
[Re: rayztoy]
#1062159
08/24/11 07:45 PM
08/24/11 07:45 PM
Posts: 21,400 It's a dry heat
gtx6970
It's a dry heat
Is that clip also used for the speedo cable on the drivers side frame rail below the brake master cylinder? TIA
Ray
This is a B-body but my challenger had one is this exact same location holding the speedo cable
[Re: rayztoy]
#1062161
08/24/11 08:06 PM
08/24/11 08:06 PM
gtx6970
It's a dry heat
Ray, Jamie at Megaparts has the clip ( link posted above ) pn0500 is the clip to the bottom right of the above picture
[Re: floyd]
#1062165
08/27/11 12:50 PM
08/27/11 12:50 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
I have two x 71 Challengers. One has it, one doesn't. The one that doesn't looks like this. Sorry, I don't have a definative answer on the years. The car that has the clip was restored at one point.
Sorry Bruce, but the e-brake cable on your black Challenger is routed incorrectly. The clip your lookin for is for the speedo cable only. The e-brake is routed through the hole behind the fender and on the inside of the framerail. The 71 Challenger does NOT use that speedo cable clip for the e-brake.
[Re: cudastruction]
#1062169
08/29/11 10:29 AM
08/29/11 10:29 AM
Posts: 4,114 MD
floyd
MD
