Re: Possible to run low 8s with cal tracks and 10,5 tire?
[Re: domingo]
#1060980
08/24/11 02:51 PM
08/24/11 02:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you guys think 33 x 10,5" is a good tire or is it a tad too tall causing the car to be unstable at higher speeds?
If you have a wing or enough down force on the back of the car the tires would be fine(would give you a larger foot print) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: domingo]
#1060981
08/24/11 04:06 PM
08/24/11 04:06 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Is it possible or is it a stretch?
caltrac's easy to hold 8's..getting everything else correct take some doing..my buds do it all the stock susp cars..but u need to tinker thats for sure ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: fishy340]
#1060982
08/24/11 04:39 PM
08/24/11 04:39 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Is it possible? Sure. Do it consistently? No.
[Re: joshking440]
#1060985
08/24/11 06:40 PM
08/24/11 06:40 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
It's been done with Mopar but generally you have to build for a shorter front spring segment.
[Re: Leon441]
#1060986
08/24/11 06:41 PM
08/24/11 06:41 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
dont you mean a longer front spring segment Leon
[Re: joshking440]
#1060987
08/25/11 09:58 AM
08/25/11 09:58 AM
Posts: 4,078 Mo.
racerx
Mo.
[Re: racerx]
#1060988
08/25/11 11:51 AM
08/25/11 11:51 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Talk to guppy (demongup) he has been in the 7s with his demon and has won 3 or 4 8.50 index races here. I would have to say his car is really consisent and is mini tubbed, cal tracs, and 10 in tire. So yes it is very possible.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: domingo]
#1060989
08/25/11 12:21 PM
08/25/11 12:21 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Start on the high side of recommended tire pressure for safety. You are on the narrow side for rims, and they become unstable faster (lower pressure) Than a wide rim combo.
[Re: domingo]
#1060991
08/26/11 12:20 AM
08/26/11 12:20 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
[Re: hemi-itis]
#1060993
08/26/11 02:07 PM
08/26/11 02:07 PM
Posts: 1,629 pa
572charger
pa
ive been there on s/s springs 8.98 at 154mph ![](/ubbthreads/images/graemlins/biggrin.gif) at 3910lbs ![](/ubbthreads/images/graemlins/biggrin.gif) on sheetz 93 octane ![](/ubbthreads/images/graemlins/biggrin.gif)
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
