360 into a 65 barracuda..what is needed? #1060654
08/23/11 10:09 PM
08/23/11 10:09 PM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
I have a 65 barracuda. It's a 273 now but what would I need besides complete 360 engine from a car or truck? I believe an engine mount is different and a flywheel? Where do I get this flywheel? Anything else different. I was for a second going to put a 4brl on the 273 and blah blah blah but I read somewhere someone said to just dress up a 360 like a 273 and be done with it...I laughed..I thought...yea probably best to do that. What is involved with a 360 swap?
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060655
08/23/11 10:49 PM
08/23/11 10:49 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
360 will drop right in, no mods needed, 340 exhaust manifolds work too. The 360 flywheel is externally balanced so the 273 flywheel not work, the 273 bellhousing is too small. My first car was a 65 BCuda 4 speed. I'ts an easy swap.
-Daty
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060656
08/23/11 10:51 PM
08/23/11 10:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I am getting ready to do exactly that.
First off, If it is from a truck you need to get a car pan and pick up.
Second thing you need is a 360 flywheel or if you have a 1/2 way competant machine shop they can balance yours to 360 specs, if you know the specs yourself you can figure out where the weight comes off and figure out how big a hole to drill and drill out the weight yourself.
Third is the slightly different motor mount, I don't know if an aftermarket mount is available or not but I always just put some washers in to take up the space and use what I have.
The balanceer needs to match the 360 and you will need to make TDC mark to match up wioth the pointer from the 273, they are in different places and setting timing will be a crap shoot. One of the bolt holes is in a different place for the crank pulley but no biggie to slot the one that don't line up so you can get a bolt in.
A factory 4bbl intake would be cool but restrict HP a bit so mabey get a performer RPM.
The 273 block has a divot in the side for drivers side ex manifold clearance, if you run manifolds mock it up on the stand and see if you need to grind a little clearance there.
Pretty much everything else bolts up the same.
Re: 360 into a 65 barracuda..what is needed? [Re: HotRodDave] #1060657
08/24/11 01:13 AM
08/24/11 01:13 AM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
Do I need a truck 360 flywheel or is this an aftermarket thing. As far as I know there wasn't too many 360 cars built...there were, we all know that but seems like it would be a rarer piece to find.
So my bell housing isn't going to work? Gotta get a 318-360 sb bell housing?
Can I get some extra 2 cents on 340 manifolds fitting? I would hate to buy them and they not fit...fairly expensive as we all know.
My car is only a 273 2brl so it's not like I'm killing a formula S car. I hate to keep changing my mind, but I think I'm a fool not to put the 360 in there.
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060658
08/24/11 01:37 AM
08/24/11 01:37 AM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Hey,I've already done this one too,I have a '66 Barracuda,originally a 273 2bbl/4speed car..I put a 360 in it in 2009,I had my local machine shop balance it using the 273 flywheel,360 balancer{the one without the extra "lip" around the front side},the rest of the install was easy,the original bellhousing and exhaust manifolds,as for the drivers mount,I used a extra nut instead of washers,,I've put around 8500 miles on it since,no problems.There's a couple pics of it in the October issue of Car Craft,took it on the Anti Tour 2009.
One side note though,because the clutch is so small,I had the pressure plate made to handle the extra torque,works better,should of had increased a bit more,,haha....good luck on the project.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 360 into a 65 barracuda..what is needed? [Re: johnnycuda] #1060659
08/24/11 02:17 AM
08/24/11 02:17 AM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
good info johnnycuda... I may use stock 273 manifolds for a tad bit til funds clear cause I have enough money spent on making this happen. Once I part out the other car...that money will be spent on manifolds etc.
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060660
08/24/11 09:18 AM
08/24/11 09:18 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Schumacher Creative Services makes motor mounts.
http://www.engine-swaps.com/Pages/ProductsYear/63.66aBody.html
Here's a helpful thread from th tech archives:
http://www.moparts.org/Tech/Archive/smallblock/11.html
This is a project I started and gave up on a few years ago, and am still kicking myself for not completing it.
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060661
08/24/11 10:53 AM
08/24/11 10:53 AM
pass car pan/pickup. Slight shimming of mtr mt on one side. machine shop will take the MP diagram & do the trig to figure exactly where to drill to convert your 'wheel to ext balance. Retain a cast WP to match your rad lower nipple/adj pulley spacing w spacers/washers. the hose/tim marks will b on the same (dr) side but you can see em if you angle the light just right. Need to retain the 273 logs which are very restrictive (1&7/8) esp on the dr side but on early A's there's a tremendous variation of tolerance stack ups & 340 HP mani's have been known to fit as is or may have to shorten the coupler to 1/2 it's length/refit the crimp on connector, alot of work but the 273 manis are (as you know) extremely restricted and parts houses have 2 sets of ex gaskets (head to mani)large or small so get the ones you need so no leak. Ain't done it but prob could use a PS col (actually the inner shaft which EASILY swaps) which is shorter w manual steering box & a firm feel adapter extension to slide by the manifold. alot of work but ex is critical & it'll b a dog if you do not adress that issue
Re: 360 into a 65 barracuda..what is needed? [Re: RapidRobert] #1060662
08/24/11 01:14 PM
08/24/11 01:14 PM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
Alright, some more good info! I have manual steering on my car and the parts car. I had a guy come over my house a couple years ago trying to figure out why his 360 65 valiant was a beast up until 3500rpms...then would kill over. I looked at those 273 manifolds he had to reuse and I said..."those manifolds are killing everything you got!" so I definately know about those manifolds! Out of curiousity how come no one has made a header to exit out of the front of the engine? Clearance when exiting under K frame?
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060663
08/24/11 02:07 PM
08/24/11 02:07 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Those manifolds are bad but not death to an engine, I had a bone stock 77 360 short block under a bone stock 273 4bbl top end in a 66 dart and it pulled good to 5000 rpm with those manifolds and drag strip testing backed that up for shift points. It went through 7.25 rear ends like toilet paper. With well thought out cam specs, ported heads, intake, tuneing... it could still make some good steam with those restrictive manifolds. Others will make more power but the freebies are not gonna be the death of a motor.
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060664
08/24/11 02:58 PM
08/24/11 02:58 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
I have a set of Jet-Hot coated Spitfire headers that I don't use anymore. PM me if you're interested.
Re: 360 into a 65 barracuda..what is needed? [Re: HotRodDave] #1060665
08/24/11 09:18 PM
08/24/11 09:18 PM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
hotroddave...yea this guy had a high 12 second motor...slicks probably a lil better..trying to breathe through those 273 manifolds. Had a .500+ lift cam in it, the works. I'm not going to go that crazy with my engine. I'm not into racing anymore so.
Valiant Showoff..pm sent!
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060666
08/24/11 10:39 PM
08/24/11 10:39 PM
Ain't used the Spitfires but the 340HP manifolds w their free flowing design/pretty easy fit/2&1/4" outlets are an excellent plan
Re: 360 into a 65 barracuda..what is needed? [Re: RapidRobert] #1060667
08/25/11 09:45 PM
08/25/11 09:45 PM
Moparland
maxxx Offline OP
maxxx  Offline OP
Moparland
I bought one of the first pairs of spitfires a long long time ago and never used them..sold them on egag because harrold took so long, I sold the car, lol. I knew I should have hid them in the garage. 340 manifolds would be nice..for that stock appearance...
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060668
08/25/11 11:36 PM
08/25/11 11:36 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We make the clutch linkage parts (torque shaft, bellhousing ball bracket, adjusting rod kit, etc) to convert 1963-66 A-bodies to the 10.5" bellhousing. We can also provide a flywheel for the cast crank 360.
Wayne/Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 360 into a 65 barracuda..what is needed? [Re: 64dodge572] #1060669
08/26/11 12:26 AM
08/26/11 12:26 AM
N.W. Florida
N.W. Florida
Wayne/Dan
I'm no master fabricator, but the clutch linkage was one of my biggest headaches. If Brewers has "off the shelf" stuff I'd jump on it. I wish I would have had this years ago when I was mocking up mine.
EDIT: As mentioned above, the 273 flywhhel really is too small for any decent 360. I would definitely use the larger 10.5" flywheel/bellhousing.
Re: 360 into a 65 barracuda..what is needed? [Re: Fat_Mike] #1060670
08/26/11 01:23 AM
08/26/11 01:23 AM
Myself I'd keep the orig bell/'wheel etc & have a clutch co build you a killer pp/disc 4 it
Re: 360 into a 65 barracuda..what is needed? [Re: maxxx] #1060671
08/26/11 07:29 AM
08/26/11 07:29 AM
Central TX
roe Offline
roe  Offline
Central TX
Wouldn't 318 or 360 manifolds be just as good. I remember and article in MoparMuscle, I believe, where they compared all the manifolds vs headers on a mild 360 IIRC. And the differences were minute between the different manifolds. Or is it just a fitment issue?
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 360 into a 65 barracuda..what is needed? [Re: roe] #1060672
08/26/11 10:38 AM
08/26/11 10:38 AM
I remem that article & I think they had a misprint on some of the tests. Yes a fitment issue on the DR side
Re: 360 into a 65 barracuda..what is needed? [Re: RapidRobert] #1060673
08/26/11 04:33 PM
08/26/11 04:33 PM
Alliance, Ohio
V
V
Alliance, Ohio
Oops, but I accidentally deleted the PM from someone asking about my Spitfires. Went to hit the "respond" button and hit "delete" instead. unfortunately my fingers are faster than my brain.....
Please resend message.
