Re: Need to go faster
[Re: cbarracuda]
#1058915
08/21/11 10:18 PM
08/21/11 10:18 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
at 3000lb you need 225 more hp to go 9.00
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: pittsburghracer]
#1058917
08/21/11 10:25 PM
08/21/11 10:25 PM
Posts: 415 Peru
cbarracuda
Peru
Put a nice big block together and you won't need the NOS.
Hey I said I wanted to go faster not slower
[Re: sixpackgut]
#1058918
08/21/11 10:27 PM
08/21/11 10:27 PM
Posts: 415 Peru
cbarracuda
Peru
Donīt you think the compression is too high for those many HP with squeeze
[Re: sixpackgut]
#1058920
08/21/11 10:46 PM
08/21/11 10:46 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Going from 10.00s to 9.20s is a big move. It is not just having the power, it is getting it to the ground as well. It takes a minimum of 770 hp to break into the 9.20s at 3,000 lbs, and a well tuned suspension/chassis. 725 Hp will get you 9.30s at 3,000. How deep are you in this?
[Re: cbarracuda]
#1058921
08/21/11 10:46 PM
08/21/11 10:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Guys run big compression with spray... just have to have the tune up right
[Re: MR_P_BODY]
#1058923
08/21/11 10:58 PM
08/21/11 10:58 PM
Posts: 415 Peru
cbarracuda
Peru
what would be the right tune up?
[Re: cbarracuda]
#1058926
08/21/11 11:40 PM
08/21/11 11:40 PM
MR_P_BODY
Dont ask me ... I dont spray... Monte Smith is the MAN to talk spraying
[Re: MR_P_BODY]
#1058927
08/22/11 12:18 AM
08/22/11 12:18 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes u can do it with a .073 jet in a plate (Wilson I like), and 9 degrees out, with a stock block. I have done it many times. But realize you are running a gerenade with the pin pulled out. It will take that punishment but not alot. It takes alot to set up a proper nitrous system, 2nd fuel system, micro switch, timing retard, c16 feul, not just a 500 dollar kit.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Thread Ender1]
#1058930
08/22/11 05:52 PM
08/22/11 05:52 PM
1967dartgt
Hilltown Pa
What plate are you going to use? nos cheaters, power shots, a speedtech plate , a wilson, single or cross bar set up? All take different jet setups.
[Re: 1967dartgt]
#1058932
08/22/11 05:59 PM
08/22/11 05:59 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
hey Brad how come 340's can handle it..but 440's blow apart at 600hp after a few passes?
