Re: Moving rearend back on a 67-up Dart...stupid question.
[Re: cudadoug]
#1058831
08/21/11 07:18 PM
08/21/11 07:18 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I moved mine back an inch but mine are under the chassis rails, i cut the old front hangers out and made new larger ones with multiple holes, i also dropped the rearend at the same time, then reset the pinion angle. I'm not sure what the offset front hangers look like but i would think you may have to fabricate something but what do i know. lol Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: cudadoug]
#1058832
08/21/11 07:21 PM
08/21/11 07:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How?? I realize you probably just are spacing the front hanger back, right? But my offset hangers only have studs that are about an inch long; therefore if you want to move the rear back an inch...how does that work??
Yea, I'm probably missing something obvious, DUH...but don't flame; stupid questions are allowed here!
Knock out the old studs and put in longer grade 8 bolts... I really wouldnt go past a 1 1/4 or so....... BUT you will need to move the shackle if you move it much
[Re: MR_P_BODY]
#1058833
08/21/11 11:10 PM
08/21/11 11:10 PM
Posts: 3,249 Between a rock & a hard place
cudadoug
Told ya it was a STUPID question! Thanks Mr. P Body. Uhhhhh, I knew that...no really I did...
[Re: cudadoug]
#1058834
08/21/11 11:17 PM
08/21/11 11:17 PM
MR_P_BODY
No dumb/stupid questions... how would people learn without asking questions........ unless you like doing it more than once ..... which I've done... because I didnt ask
