Moving rearend back on a 67-up Dart...stupid question. #1058830
08/21/11 06:57 PM
08/21/11 06:57 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
How?? I realize you probably just are spacing the front hanger back, right? But my offset hangers only have studs that are about an inch long; therefore if you want to move the rear back an inch...how does that work??
Yea, I'm probably missing something obvious, DUH...but don't flame; stupid questions are allowed here!
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: cudadoug] #1058831
08/21/11 07:18 PM
08/21/11 07:18 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I moved mine back an inch but mine are under the chassis rails, i cut the old front hangers out and made new larger ones with multiple holes, i also dropped the rearend at the same time, then reset the pinion angle.
I'm not sure what the offset front hangers look like but i would think you may have to fabricate something but what do i know. lol
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: cudadoug] #1058832
08/21/11 07:21 PM
08/21/11 07:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Knock out the old studs and put in longer grade 8 bolts...
I really wouldnt go past a 1 1/4 or so....... BUT
you will need to move the shackle if you move it much
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: MR_P_BODY] #1058833
08/21/11 11:10 PM
08/21/11 11:10 PM
cudadoug Offline OP
cudadoug  Offline OP
Told ya it was a STUPID question! Thanks Mr. P Body. Uhhhhh, I knew that...no really I did...
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: cudadoug] #1058834
08/21/11 11:17 PM
08/21/11 11:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No dumb/stupid questions... how would people learn
without asking questions........ unless you like doing
it more than once ..... which I've done...
because I didnt ask
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: cudadoug] #1058835
08/21/11 11:26 PM
08/21/11 11:26 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Who sells good leaf spring hanger spacers?
Re: Moving rearend back on a 67-up Dart...stupid question. [Re: topbrent] #1058836
08/21/11 11:32 PM
08/21/11 11:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You can make spacers out of plate. Don't forget to lengthen the driveshaft so it has adequate support inside the tail housing.
