converter lock-up no workie #1058670
08/21/11 02:56 PM
08/21/11 02:56 PM
USA
540DUSTER Offline OP
USA
I have a 98 neon that the lock-up on converter isn't working.I have 12 volts going to solenoid located on trans.Jumped the solenoid and it works.I think the computer isn't doing its job of grounding the circuit.If somebody can tell me what pin number is the ground on the computer,I would be real thankful.Can't get car inspected with check engine light on.
Re: converter lock-up no workie [Re: 540DUSTER] #1058671
08/21/11 03:23 PM
08/21/11 03:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried disconnecting the battery for a bit and then seeing if the problem continues?
Re: converter lock-up no workie [Re: stumpy] #1058672
08/21/11 03:32 PM
08/21/11 03:32 PM
USA
USA
yes,I had to pull the batt. to test the solenoid.I don,t have the equipment to clear the code.
Re: converter lock-up no workie [Re: 540DUSTER] #1058673
08/21/11 03:38 PM
08/21/11 03:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most local parts stores will read and then erase the codes for free.
Re: converter lock-up no workie [Re: stumpy] #1058674
08/21/11 03:58 PM
08/21/11 03:58 PM
USA
USA
when this problem first started,the lock-up would stop working and the light would come on usually on a cold damp day.When the weather got better the lock-up would work and the light would reset itself.It quit fixing itself.I'am thinking the connection to the computer may be bad or the computer itself.I don't know much about these computer cars,If I get a computer at a junk yard can I just hook it up or do you have to flash the computer to work in my car?
