Spot Welders #1058179
08/20/11 10:58 PM
08/20/11 10:58 PM
Anonymous OP
Anonymous OP
Who has ideas on spot welders that are easy on the wallet but work nicely??
Re: Spot Welders #1058180
08/21/11 04:48 AM
08/21/11 04:48 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Should be 240volts, highest possible kva rating possible.
I use a tecna portable; easily does wheel lips, even inner panel installs. Not cheap, but much less then the bigger shop types.
Re: Spot Welders #1058181
08/21/11 08:46 PM
08/21/11 08:46 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I have both Harbor Freight models...the 120 and 220volt. The 120v needs a 30amp breaker so it won't keep tripping. There are also different size arms available to get into hard to to reach areas.
and then there are the Lenco spot welders.. They show up all the time used from body shops. A new Lenco starts at $800 or so but are more versatile.
Re: Spot Welders [Re: 52savoy] #1058182
08/21/11 08:59 PM
08/21/11 08:59 PM
smyrna,tn
draginmopars Offline
smyrna,tn
we also have a harbor freight 220 volt does fine.
not used often, but , nice to have when needed
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Spot Welders [Re: draginmopars] #1058183
08/21/11 09:11 PM
08/21/11 09:11 PM
Anonymous OP
Anonymous OP
Thanks for the input! What do you guys do where you want the appearance of a factory spot but cant fit the tongs? For instance cowls on an E body firewall?
Re: Spot Welders [Re: PhillyRag] #1058184
08/21/11 09:57 PM
08/21/11 09:57 PM
sixbbl69 Offline
sixbbl69  Offline
Linco 4000 L spot welder.
Re: Spot Welders [Re: sixbbl69] #1058185
08/21/11 10:21 PM
08/21/11 10:21 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Spot Welders #1058186
08/21/11 10:22 PM
08/21/11 10:22 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Re: Spot Welders [Re: 52savoy] #1058187
08/22/11 07:14 AM
08/22/11 07:14 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you don't mind used...
http://www.ebay.com/itm/Ets-Louis-Melzas...=item4cf907e7d1
I have a Marquette similar to that except the tongs are separate, each with its own cable. Someday I'll get to try it!!
Re: Spot Welders [Re: 6PakBee] #1058188
08/22/11 10:19 AM
08/22/11 10:19 AM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Lenco Panel Spotter
Watch for them on Craigslist, I got mine for $250 2 years ago.
Re: Spot Welders #1058189
08/22/11 05:13 PM
08/22/11 05:13 PM
O
OLD318 Offline
OLD318  Offline
O
This depends on what thickness of metal you wish to spot weld
and what do you mean by "easy" on the wallet.
The Lenco L-4000 MKII that is referred to here cost almost $1000.00 brand new
but its only rated for 20 guage sheet metal
and requires a 50 amp single phase plug.
This means that you can certainly get one of these and plug
it in at home-(you might need an electrician to setup the
plug for you), But this only buys you 20guage spot welding)....
IMHO...
The smaller portable types ($400-$750 new) even those which
utilize a 230volt 30 amp plug,may work OK with thinner metal
20 guage 22 guage etc. But I don't see how they will work on
18 guage to 18 guage as found on the old mopars...
Others on here will differ on this opinion I'm sure
and I'm not trying to start a fight.
I'm just saying I don't see how... etc...
The professional spot welders used by the factory usually (if not always) require 3-phase commercial plugs...
You can't get that in a residential setting. (Single phase)...
and they generate 1000's of amps to do this correctly.
Whats wrong with MIG Welding?
Re: Spot Welders [Re: OLD318] #1058190
08/22/11 05:52 PM
08/22/11 05:52 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Sort of;
my larger spot welder is rated at 19,000 amps at the secondary coil, but that translates to a 30 amp 208/3/60 service. My smaller Miller unit takes a 20amp breaker.
I don't know what those little ones are rated at, but while the amperage of the welder is part of the equation, we simply adjust the weld time to deal with most thicknesses of sheet metal.
I also question whether or not most mopars have 18ga exterior panels.....the few I micrometered didn't; 20-22ga IIRC.
I wouldn't trust some hobbiest spot welder on subframes, K frames or the like, but I'm sure most decent ones don't have a problem with outer body panels....course you have to make sure the metal is clean, contact is tight with adequate pressure and the tips are in good shape....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Spot Welders [Re: DPelletier] #1058191
08/22/11 06:11 PM
08/22/11 06:11 PM
Anonymous OP
Anonymous OP
This is why I posted to get as much info i can before i make a move. Heres what I am hoping to achieve:
Spend less than a grand on one.
Get a respectable factory appearing weld. (I know it wont ever be that nice original factory spot, but I want to try getting it)
Get a little more satisfaction doing it myself without giving up cleanliness and quality that i may or may not get paying someone else to do.
I appreciate all input, ideas, and past experiences, its what makes this site great for the hobbyist!
Re: Spot Welders #1058192
08/22/11 06:18 PM
08/22/11 06:18 PM
DPelletier Offline
DPelletier  Offline
Actually, I can easily duplicate a factory spot weld perfectly with either of my machines.
Re: Spot Welders #1058193
08/22/11 06:20 PM
08/22/11 06:20 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
A flat nosed punch with a dolley. It's a two man job but its cheap.
Getting old just means you were smarter than some and luckier than others.
Re: Spot Welders [Re: dannysbee] #1058194
08/22/11 08:51 PM
08/22/11 08:51 PM
Anonymous OP
Anonymous OP
I was thinking of something like that today, wondering if it would look good. Looked like the metal was crimped in a lot from the factory.
Re: Spot Welders [Re: DPelletier] #1058195
08/22/11 10:54 PM
08/22/11 10:54 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I do that easily with the 120V HF welder I go all over(add welds) the body(s) to stiffen it up. Just leave the switch on longer for deeper welds and they are identical to the factory welds.
Re: Spot Welders [Re: DPelletier] #1058196
08/23/11 01:57 AM
08/23/11 01:57 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Dave, What brand of welders are you using? Can you post pictures of your welds? Thanks!
Re: Spot Welders [Re: 52savoy] #1058197
08/23/11 01:59 AM
08/23/11 01:59 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Can you post pictures of your welds and the welder you use? Thanks!
Re: Spot Welders [Re: sixpaktoogo] #1058198
08/23/11 02:15 PM
08/23/11 02:15 PM
DPelletier Offline
DPelletier  Offline
I have a sheet metal fabrication shop, so mine aren't what most hobbiests would have access to. I have a Western Arctronics 30KVA and a Miller 20FT. The Miller is convertable to portable duty, the Western is not. If you still want pics, let me know.
