Re: best place to install o2 sensor
[Re: a493demon]
#1056729
08/19/11 12:57 PM
08/19/11 12:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put the bung in BEFORE/up stream of the evac or you will get a bad reading on the O2 and it should be mounted so its above the centerline of the tube so it doesnt collect moisture
[Re: fishy340]
#1056731
08/19/11 03:33 PM
08/19/11 03:33 PM
Posts: 6,295 U.S.
moparniac
U.S.
I run an evac system and full exhaust! my sensor is right in the x pipe! no issues at all and the plugs read what the wideband is saying. Id imagine with open headers and the sensor right behind the evac nipple could give false readings...
Mopar Performance
[Re: moparniac]
#1056732
08/19/11 03:40 PM
08/19/11 03:40 PM
MR_P_BODY
I will guarantee that the readings your getting are NOT TRUE readings... its seeing vapors from the engine also ... is it going to be way off ... I did the O2 stuff for Chrysler for YEARS
[Re: MR_P_BODY]
#1056733
08/19/11 04:00 PM
08/19/11 04:00 PM
Posts: 6,295 U.S.
moparniac
U.S.
Im just saying what mine does not arguing with ya! I drive on the street alot testing and pull plugs all the time! had my SV1 apart SEVERAL times even changing orifice sizes in the main body! my plugs were dead rich when my wideband said it! I have a good clean street tune now and the plugs look great! when im running rich my sensor looks like a rich plug! when im running good the sensor is clean like a plug would be! I set my car up rich before going to the track and drove to a car show and played around some on the street! whenever my SV1 is too rich it stumbles for a hair going from part throttle to getting on it... and yes when I checked them plugs they were way rich (just sayin) here is one vid from testing on the street! with the way the thing bounces around some not sure how you would say its off one way or the other! I think its a great tool and lets me know what going on"ish" I guess http://www.youtube.com/watch?v=hbyM0Rw0RWw
Mopar Performance
[Re: moparniac]
#1056734
08/19/11 04:04 PM
08/19/11 04:04 PM
MR_P_BODY
Do what ever you want, I'm just telling you a fact
[Re: MR_P_BODY]
#1056738
08/20/11 10:42 AM
08/20/11 10:42 AM
Posts: 16,923 NC
440Jim
NC
I agree. The evac may only be a slight error under some conditions, but I don't know how much. And light throttle may be worse than full throttle. Get the best measurement you can.
[Re: 440Jim]
#1056739
08/20/11 05:44 PM
08/20/11 05:44 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Mr.P I'm also interested on the right way to mount the sensor. Do you have a picture or something to referate to the mounting point. My car is a dart with 340, doug headers and 3 " exhaust system, should it be down on top of the collector? Thanks
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: MrSixpack]
#1056740
08/20/11 06:15 PM
08/20/11 06:15 PM
MR_P_BODY
No I dont have any pics but mount it like I said... forward of any e-vac and above the horizontal so it wont collect moistue
