1962/1963 era Period Correct B/RB #1056291
08/18/11 04:49 PM
08/18/11 04:49 PM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
I'm putting together a period correct 1962 or 1963 era B/RB engine for a 1931 Ford Coupe hot rod I'm building. I have some great parts collected already for it, but I've been wondering.
What is the best cylinder head casting I should be looking for?
Remember, I will only be able to use the 4 bolt valve cover heads, and currently the Max Wedge heads are out of my price range.
Induction will likely be a 2x4, although I have an NOS three Stromberg manifold which is tempting...
Re: 1962/1963 era Period Correct B/RB [Re: rabid scott] #1056292
08/18/11 11:46 PM
08/18/11 11:46 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
You can bolt the 4 bolt covers onto the late model 6 bolt heads, you just won't have bolts in the two bottom head bolt holes. The gaskets will seal the holes closed. Then you can use the much better later heads, unless you really need to stay with the 4 bolt heads. I doubt any 4 bolt heads are any better then any other 4 bolt head. Gene
Re: 1962/1963 era Period Correct B/RB [Re: poorboy] #1056293
08/19/11 01:04 AM
08/19/11 01:04 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
kool in take, but are those 97s ?? and are they enough for that motor??
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1962/1963 era Period Correct B/RB [Re: fstfish66] #1056294
08/19/11 03:54 PM
08/19/11 03:54 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
I could use later heads, but they wouldn't be period correct, would they?
What casting number heads would the 400 horse 1962 Chrysler 300 413 with two 4bbl carbs have? These wouldn't be Max Wedge heads right?
Fsh, those are three ECG5 Holley 94s for show, I have a few 97s and 48s I could use. Three of them wouldn't adequately feed a B/RB, you're right, as a trio I think they'd only come in a total of about 600 or so CFM!
Kinda why I'm thinking about running the 2x4. I'd love a Weiand Drag Star 6x2 setup, but they don't come up for sale everyday and the last couple I've seen people wouldn't split the carbs and manifolds up.
Re: 1962/1963 era Period Correct B/RB [Re: rabid scott] #1056295
08/19/11 06:11 PM
08/19/11 06:11 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
The best head of that era, excluding max wedge, would be the head used on the 1963 Chrysler 300J. These would have the larger 1.74" exhaust valve. Casting number is 2402557.
1979 AMC Spirit, NHRA Q/SA
