Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: BobR] #1056073
08/19/11 10:37 AM
08/19/11 10:37 AM
State of confusion
Thumperdart Offline OP
State of confusion
Makes sense.........
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: Cab_Burge] #1056074
08/19/11 11:09 AM
08/19/11 11:09 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Jason did my 527 block before we moved here, the 518 street motor is not bushed. The 518 made 775 HP on Oregon pump gas with the same carb that the 527 made 845 HP on race gas, both with the same set of ported Indy 440-1 heads I have piched a roller lifter out(the old bracket Duster) when a valve spring broke and bent the pushrod, oil pressure went to zero, the 527 motor broke a Smith Bros pushrod on the dyno testing and both lifters came out, no oil pressure loss
Cab, is this with a STOCK OEM block?
Puting bushing's in the bores and "correcting" geometry with bushings are 2 different things.
Has anybody degreed their cam in on #1 intake and then went and checked say #8 intake lobe to see where it comes in at on a OEM uncorrected block?
I don't have enough parts to put something together to do this but someone may have the parts and time
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: roadhazard] #1056075
08/19/11 01:22 PM
08/19/11 01:22 PM
I did that stock block to correct the angles( thye probally where okay, I didn't check the angles, they had .0025 + clearances then) and insure that I wouldn't loose oil pressure if the lifters came out. I have check cam lobes on both #1 and #6, you don't have to move the degree wheel to keep TDC in the same place , and found a bad cam grind when I had it check on a cam Doctor
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: Darryls-Demon] #1056076
08/19/11 06:21 PM
08/19/11 06:21 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A good friend called me tonight, he is having a 426 Hemi rebuilt and the bill for bushing the lifter bores was right at a thousand dollars. This was on a MP block.
Is he having Key Way lifters fitted?
Alan Jones
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: roadhazard] #1056077
08/19/11 08:55 PM
08/19/11 08:55 PM
Guitar Jones Offline
I did mine when I assembled the new shortblock just because I was curious and it wasn't off but maybe .5 degree. Were any others off? I don't know but that's pretty darn close for an old Crane grind if you ask me.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: Guitar Jones] #1056078
08/19/11 11:49 PM
08/19/11 11:49 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
This thread is jogging a bit of remembered tech from back in the 70's. When and only when, running a roller cam some guys would bush the Mopar lifter bore .904 to chevy .842 so they could use a lighter and cheaper chevy roller lifter. The wider base circle of the mopar didn't really make much difeerence with a roller lifter. Anybody else remember this?
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: Cudajon] #1056079
08/20/11 08:24 AM
08/20/11 08:24 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I would be interested to see if anyone on here has done this. When I asked my machine shop about this they said why would you do this when chev guys take theirs out to .904 size. I have not found a chev guy yet running anything but .842.
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: mac56] #1056080
08/20/11 10:20 AM
08/20/11 10:20 AM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The correction of geometry, decrease in wear, improvement in alignment- those are all great reasons to bush the lifter bores, but the biggest reason I have is for the oil control. Try priming a BBM or Hemi with the intake off it and watch the GALLONS of oil that push by the lifter bores. We frequently run only standard oil pumps in bushed motors, no HV needed, and we also frequently need to REDUCE the oil pressure in those same motors after controlling the massive leaks from the lifter bores.
Be a Rebel- Break the Laws of Physics!
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: mbogina] #1056081
08/20/11 11:28 AM
08/20/11 11:28 AM
State of confusion
State of confusion
Now THIS has me really considering this mod. Man, 8 years ago when I freshoned this thing I had thousands of(credit card)dollars to work with and never really thaught about it and even the machinest(s) didn`t recommend it or they`d be in now.
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: mbogina] #1056082
08/20/11 01:24 PM
08/20/11 01:24 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have a SB with lifter bushings and a few other mods and with a plain old standard Melling pump I still have more pressure than I really need
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: LA360] #1056083
08/21/11 02:15 AM
08/21/11 02:15 AM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Thats what iam thinking JESEL keyway bushings are 35ish each
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: MCHBOB] #1056084
08/21/11 01:39 PM
08/21/11 01:39 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
No they are standard bushings. He will be using Crower lifters.
Re: BUSHED LIFTER BORES IN STOCK BLOCK............. [Re: mbogina] #1056085
08/22/11 06:50 AM
08/22/11 06:50 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I have primed without valley pan and it was frightening how much oil comes out around the bottom of the lifter.
